Ir para o conteúdo principal
HP x2 10-p010wm Speaker Replacement
O que você precisa
  1. HP x2 10-p010wm Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Pull the screen away from the keyboard.
  2. HP x2 10-p010wm Speaker Replacement: passo 2, imagem 1 %32 HP x2 10-p010wm Speaker Replacement: passo 2, imagem 2 %32
    • Insert a spudger into the space between the screen and computer and gently pry the two pieces apart. Continue this around the whole screen.
  3. HP x2 10-p010wm Speaker Replacement: passo 3, imagem 1 %32
    • Slowly disconnect the thin wire attaching the screen to the rest of the computer by holding one end and sliding it down.
    • Do not pull up too hard; slowly slide it towards the screen.
  4. HP x2 10-p010wm Speaker Replacement: passo 4, imagem 1 %32
    • Remove the eight 4mm Phillips #00 screws from the metal plate.
  5. HP x2 10-p010wm Speaker Replacement: passo 5, imagem 1 %32 HP x2 10-p010wm Speaker Replacement: passo 5, imagem 2 %32 HP x2 10-p010wm Speaker Replacement: passo 5, imagem 3 %32
    • Slowly peel up any tape securing the wire to the metal cover.
    • Remove the metal cover to access the battery.
  6. HP x2 10-p010wm Speaker Replacement: passo 6, imagem 1 %32
    • Remove the 4mm screw on the side.
  7. HP x2 10-p010wm Speaker Replacement: passo 7, imagem 1 %32
    • Remove the black tape.
    • Pull the battery connector towards the battery to disconnect it from its socket.
  8. HP x2 10-p010wm Speaker Replacement: passo 8, imagem 1 %32
    • Remove the battery.
  9. HP x2 10-p010wm Speaker Replacement, Speaker: passo 9, imagem 1 %32 HP x2 10-p010wm Speaker Replacement, Speaker: passo 9, imagem 2 %32
    • Remove speakers on both sides.
Conclusão
Uma outra pessoa concluiu este guia.
Nathan Ojala
Membro desde: 10/30/19
317 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S4-G3, Saloman Fall 2019 Membro de UMass Dartmouth, Team S4-G3, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G3
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 168
