Ir para o conteúdo principal
HP ZBook 15 Wi-Fi Card Replacement
O que você precisa
  1. HP ZBook 15 Wi-Fi Card Replacement, Battery: passo 1, imagem 1 %32 HP ZBook 15 Wi-Fi Card Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Wi-Fi Card Replacement, Back Cover: passo 2, imagem 1 %32
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 1 %32
    • Lift up the two tabs connected to wires.
  4. HP ZBook 15 Wi-Fi Card Replacement: passo 4, imagem 1 %32 HP ZBook 15 Wi-Fi Card Replacement: passo 4, imagem 2 %32
    • Remove the two 3mm screws from the corners of the card with a Phillips #0 screwdriver.
    • Lift the card up and slide it out to disconnect it.
Conclusão
3 outras pessoas executaram este guia.
Grant Terris
Membro desde: 01/30/15
2.828 Reputação
Autoria de 12 guias
Equipe
Cal Poly, Team 8-43, Amido Winter 2015 Membro de Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
Membros da 4
Autoria de 15 guias
Um comentário
I’m planning to upgrade my Zbook by installing a Wireless AC-capable WiFi module. I’ve found a cheap one that’s compatible according to the service manual: the Intel 7260HMW. However, it doesn’t have an HP SPS, it seems to have come from a DELL laptop.
Has anyone tried this? Will it work? I guess I’ll find out the hard way!
Hopefully, the seller will allow me to test the adapter before buying.
Luis Alejandro Araúz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 40
Duração total: 5,482
