Introdução
Are you having problems with your wi-fi? Here is some more information about why you might not be able to connect to wireless networks. If you determine that your wi-fi card needs to be replaced, follow this replacement guide!
O que você precisa
Flip the laptop over.
Slide the lever with the battery symbol beside it firmly until the battery pops out.
Remove the battery from the laptop.
Slide the right lever firmly to the right.
Slide the cover towards yourself to remove it.
3 outras pessoas executaram este guia.
1Comentário do guia
I’m planning to upgrade my Zbook by installing a Wireless AC-capable WiFi module. I’ve found a cheap one that’s compatible according to the service manual: the Intel 7260HMW. However, it doesn’t have an HP SPS, it seems to have come from a DELL laptop.
Has anyone tried this? Will it work? I guess I’ll find out the hard way!
Hopefully, the seller will allow me to test the adapter before buying.
