Ir para o conteúdo principal
HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement
O que você precisa
  1. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: passo 1, imagem 1 %32 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: passo 1, imagem 2 %32 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: passo 1, imagem 3 %32
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
    Pergunte ao FixBot
    Comentar
  2. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Shell: passo 2, imagem 1 %32 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Shell: passo 2, imagem 2 %32
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: passo 3, imagem 1 %32 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: passo 3, imagem 2 %32 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: passo 3, imagem 3 %32
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: passo 4, imagem 1 %32 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: passo 4, imagem 2 %32
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S18-G5, White Winter 2019 Membro de Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 1,179
