Ir para o conteúdo principal
HP Stream 7 Screen Replacement
O que você precisa
  1. HP Stream 7  Screen Replacement, Battery: passo 1, imagem 1 %32 HP Stream 7  Screen Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the tablet is powered off before beginning.
    • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
    Pergunte ao FixBot
    Comentar
  2. HP Stream 7  Screen Replacement: passo 2, imagem 1 %32 HP Stream 7  Screen Replacement: passo 2, imagem 2 %32
    • Remove the eight 5 mm Phillips 000 screws.
    • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
    Pergunte ao FixBot
    Comentar
  3. HP Stream 7  Screen Replacement: passo 3, imagem 1 %32 HP Stream 7  Screen Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
    • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
    • If you broke both tabs, scrape the tape and Battery off.
    • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
    Pergunte ao FixBot
    Comentar
  4. HP Stream 7  Screen Replacement, Motherboard Replacement: passo 4, imagem 1 %32
    • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
    • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
    • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
    • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
    Pergunte ao FixBot
    Comentar
  5. HP Stream 7  Screen Replacement: passo 5, imagem 1 %32 HP Stream 7  Screen Replacement: passo 5, imagem 2 %32
    • Remove the two 2 mm Phillips 000 screws from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. HP Stream 7  Screen Replacement: passo 6, imagem 1 %32 HP Stream 7  Screen Replacement: passo 6, imagem 2 %32
    • Once unscrewed, the motherboard separates from the rest of the device.
    • The speaker is soldered to the motherboard, but it comes off easily.
    • Forced separation may result in a damaged motherboard and/or personal injury.
    Pergunte ao FixBot
    Comentar
  7. HP Stream 7  Screen Replacement, Screen Replacement: passo 7, imagem 1 %32
    • After removing the motherboard, unscrew the four 2.5 mm Phillips 000 screws from the display panel.
    Pergunte ao FixBot
    Comentar
  8. HP Stream 7  Screen Replacement: passo 8, imagem 1 %32
    • Using your spudger, pry the display panel off the front.
    Pergunte ao FixBot
    Comentar
  9. HP Stream 7  Screen Replacement: passo 9, imagem 1 %32
    • The screen should now just come right off. Be sure to catch any broken bits if the screen is damaged.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Justin Schnorf
Membro desde: 10/03/16
252 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 18-5, Forte Fall 2016 Membro de Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
4 Membros
Autoria de 6 guias
6Comentários do guia
where can i buy new screen????
eibrims - Responder Compartilhar
Yeah, I want to know where I can buy a screen for my hp stream 7.
Rider Sd - Responder Compartilhar
Where can i buy a new screen for the stream 7 please??
migueajr - Responder Compartilhar
Same question but no answer !
Where can anyone find replacement screen online ??
Ahmed Saleh - Responder Compartilhar
We're I can buy the replacement screen?
Raymond Borrero - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 4,702
