Ir para o conteúdo principal
HP Stream 7 Motherboard Replacement
O que você precisa
    1. HP Stream 7  Motherboard Replacement, Battery: passo 1, imagem 1 %32 HP Stream 7  Motherboard Replacement, Battery: passo 1, imagem 2 %32
      • Make sure the tablet is powered off before beginning.
      • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
      Pergunte ao FixBot
      Comentar
    2. HP Stream 7  Motherboard Replacement: passo 2, imagem 1 %32 HP Stream 7  Motherboard Replacement: passo 2, imagem 2 %32
      • Remove the eight 5 mm Phillips 000 screws.
      • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
      Pergunte ao FixBot
      Comentar
    3. HP Stream 7  Motherboard Replacement: passo 3, imagem 1 %32 HP Stream 7  Motherboard Replacement: passo 3, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
      • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
      • If you broke both tabs, scrape the tape and Battery off.
      • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
      Pergunte ao FixBot
      Comentar
    1. HP Stream 7  Motherboard Replacement, Motherboard Replacement: passo 4, imagem 1 %32
      • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
      • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
      • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
      • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
      Pergunte ao FixBot
      Comentar
    2. HP Stream 7  Motherboard Replacement: passo 5, imagem 1 %32 HP Stream 7  Motherboard Replacement: passo 5, imagem 2 %32
      • Remove the two 2 mm Phillips 000 screws from the motherboard.
      Pergunte ao FixBot
      Comentar
    3. HP Stream 7  Motherboard Replacement: passo 6, imagem 1 %32 HP Stream 7  Motherboard Replacement: passo 6, imagem 2 %32
      • Once unscrewed, the motherboard separates from the rest of the device.
      • The speaker is soldered to the motherboard, but it comes off easily.
      • Forced separation may result in a damaged motherboard and/or personal injury.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Justin Schnorf
Membro desde: 10/03/16
252 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 18-5, Forte Fall 2016 Membro de Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 41
Ao todo: 2,097
