Ir para o conteúdo principal
HP Stream 13-c010nr Display Replacement
O que você precisa
  1. HP Stream 13-c010nr Display Replacement, laptop: passo 1, imagem 1 %32
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  2. HP Stream 13-c010nr Display Replacement: passo 2, imagem 1 %32 HP Stream 13-c010nr Display Replacement: passo 2, imagem 2 %32
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
    Pergunte ao FixBot
    Comentar
  3. HP Stream 13-c010nr Display Replacement: passo 3, imagem 1 %32 HP Stream 13-c010nr Display Replacement: passo 3, imagem 2 %32
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
    Pergunte ao FixBot
    Comentar
  4. HP Stream 13-c010nr Display Replacement: passo 4, imagem 1 %32
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
    Pergunte ao FixBot
    Comentar
  5. HP Stream 13-c010nr Display Replacement, Display: passo 5, imagem 1 %32
    • Remove the screw covers from the bottom corner edges of the screen.
    Pergunte ao FixBot
    Comentar
  6. HP Stream 13-c010nr Display Replacement: passo 6, imagem 1 %32 HP Stream 13-c010nr Display Replacement: passo 6, imagem 2 %32
    • Remove the two 5mm Phillips #0 screws from the screen bezel.
    Pergunte ao FixBot
    Comentar
  7. HP Stream 13-c010nr Display Replacement: passo 7, imagem 1 %32 HP Stream 13-c010nr Display Replacement: passo 7, imagem 2 %32
    • Wedge the plastic opening tool between the frame of the screen and the casing of the laptop.
    • Pry upwards on the plastic opening tool to separate the bezel from the display.
    Pergunte ao FixBot
    Comentar
  8. HP Stream 13-c010nr Display Replacement: passo 8, imagem 1 %32
    • Remove the four 3mm Phillips #0 screws from the screen.
    Pergunte ao FixBot
    Comentar
  9. HP Stream 13-c010nr Display Replacement: passo 9, imagem 1 %32
    • Use a spudger to flip up the retaining flap on the screen ribbon cable ZIF socket.
    • Pull the ribbon cable out of the ZIF socket.
    • Remove the screen.
    Pergunte ao FixBot
    Comentar
Conclusão
Keegan Lapham
Membro desde: 02/22/18
759 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S1-G3, Cagle Spring 2018 Membro de USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 1,051
