Introdução
A short battery life on the HP Stream 13-c010nr is a common problem experienced. Follow this guide to do the replacement yourself.
O que você precisa
Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
Remove the eight 5mm Phillips #0 screws from the battery.
Disconnect the battery from the motherboard.
Pull the battery up and out of the laptop.
Uma outra pessoa concluiu este guia.
