Ir para o conteúdo principal
HP Stream 11-d020nr Trackpad Replacement
O que você precisa
  1. HP Stream 11-d020nr Trackpad Replacement, Lower Case: passo 1, imagem 1 %32 HP Stream 11-d020nr Trackpad Replacement, Lower Case: passo 1, imagem 2 %32 HP Stream 11-d020nr Trackpad Replacement, Lower Case: passo 1, imagem 3 %32
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
    Pergunte ao FixBot
    Comentar
  2. HP Stream 11-d020nr Trackpad Replacement: passo 2, imagem 1 %32 HP Stream 11-d020nr Trackpad Replacement: passo 2, imagem 2 %32
    • Remove the eleven 5.6 mm Phillips #00 screws.
    Pergunte ao FixBot
    Comentar
  3. HP Stream 11-d020nr Trackpad Replacement: passo 3, imagem 1 %32 HP Stream 11-d020nr Trackpad Replacement: passo 3, imagem 2 %32 HP Stream 11-d020nr Trackpad Replacement: passo 3, imagem 3 %32
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
    Pergunte ao FixBot
    Comentar
  4. HP Stream 11-d020nr Trackpad Replacement: passo 4, imagem 1 %32 HP Stream 11-d020nr Trackpad Replacement: passo 4, imagem 2 %32 HP Stream 11-d020nr Trackpad Replacement: passo 4, imagem 3 %32
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
    Pergunte ao FixBot
    Comentar
  5. HP Stream 11-d020nr Trackpad Replacement, Trackpad: passo 5, imagem 1 %32 HP Stream 11-d020nr Trackpad Replacement, Trackpad: passo 5, imagem 2 %32
    • On the back of the plastic keyboard cover, remove the two 2 mm Phillips #000 screws.
    Pergunte ao FixBot
    Comentar
  6. HP Stream 11-d020nr Trackpad Replacement: passo 6, imagem 1 %32
    • Lift up the plastic cover to release the ClickPad.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your computer, follow these instructions in reverse order.
4 outras pessoas executaram este guia.
Spenser Mason
Membro desde: 02/04/16
1.781 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 3-5, Wollert Spring 2016 Membro de USF Tampa, Team 3-5, Wollert Spring 2016
USFT-WOLLERT-S16S3G5
5 Membros
Autoria de 19 guias
2Comentários do guia
windows 8.1 y windows 10 no detectan el clickpad ni en el administrador de dispositivos, como si no existiera pero al arrancar de un cdlive de ubuntu lo reconoce perfectamente. alguien sabra que podria ser?
Oscar - Responder Compartilhar
Can you give the Product number of the part?
NÖME Technologys and Designs - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 30
Ao todo: 1,840
