Ir para o conteúdo principal
HP Split x2 Screen Replacement
O que você precisa
    1. HP Split x2 Screen Replacement, Rear Cover: passo 1, imagem 1 %32
      • Opening the device voids the manufacturer warranty.
      • Power down the HP Split x2 before beginning the repair
      • Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
      Pergunte ao FixBot
      Comentar
    2. HP Split x2 Screen Replacement: passo 2, imagem 1 %32 HP Split x2 Screen Replacement: passo 2, imagem 2 %32 HP Split x2 Screen Replacement: passo 2, imagem 3 %32
      • Remove the four white caps on the bottom edge of the tablet.
      • Use a tweezer to grasp white caps.
      • The white caps are easily lost. Store them in a secure place.
      Pergunte ao FixBot
      Comentar
    3. HP Split x2 Screen Replacement: passo 3, imagem 1 %32
      • Use a Phillips #000 screwdriver to remove the four 3mm screws.
      Pergunte ao FixBot
      Comentar
    4. HP Split x2 Screen Replacement: passo 4, imagem 1 %32 HP Split x2 Screen Replacement: passo 4, imagem 2 %32
      • Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet.
      • Only the top and sides have tabs. Remove all tabs before lifting screen.
      Pergunte ao FixBot
      Comentar
    5. HP Split x2 Screen Replacement: passo 5, imagem 1 %32 HP Split x2 Screen Replacement: passo 5, imagem 2 %32
      • Separate the cover and the screen.
      • Gently lift the screen out of the cover.
      Pergunte ao FixBot
      Comentar
    1. HP Split x2 Screen Replacement, Screen: passo 6, imagem 1 %32 HP Split x2 Screen Replacement, Screen: passo 6, imagem 2 %32
      • Use a J0 screwdriver to remove the ten 4mm Phillips screws.
      Pergunte ao FixBot
      Comentar
    2. HP Split x2 Screen Replacement: passo 7, imagem 1 %32 HP Split x2 Screen Replacement: passo 7, imagem 2 %32
      • Peel back the large black tape.
      • Remove the 4mm Phillips screw.
      Pergunte ao FixBot
      Comentar
    3. HP Split x2 Screen Replacement: passo 8, imagem 1 %32 HP Split x2 Screen Replacement: passo 8, imagem 2 %32 HP Split x2 Screen Replacement: passo 8, imagem 3 %32
      • Remove three 2 mm zero insertion force (ZIF) connectors. Lift the black tab in front and then remove the ribbon from the rear.
      • Remove two larger zero insertion force (ZIF) connectors. Lift the black tab in front and then remove the ribbon from the rear.
      Pergunte ao FixBot
      Comentar
    4. HP Split x2 Screen Replacement: passo 9, imagem 1 %32 HP Split x2 Screen Replacement: passo 9, imagem 2 %32 HP Split x2 Screen Replacement: passo 9, imagem 3 %32
      Ferramenta utilizada neste passo:
      • The last attachment to the screen is the bronze colored display cable connector.
      • Use a pair of tweezers to lift the metal bar and swing it to the other side on top of the cable.
      • Pull in the direction of the cable to remove the connector.
      Pergunte ao FixBot
      Comentar
    5. HP Split x2 Screen Replacement: passo 10, imagem 1 %32
      • Glue is holding the device together along the edges. The glue is can be very strong. A heat gun may be required to loosen the glue for removal of the digitizer to prevent damage to the screen.
      • Apply pressure to to the sides of the tablet.
      • Separate the digitizer from the the body of the tablet.
      Pergunte ao FixBot
      Comentar
    6. HP Split x2 Screen Replacement: passo 11, imagem 1 %32 HP Split x2 Screen Replacement: passo 11, imagem 2 %32
      • Glue is holding the screen on at the four corners.
      • Lift the screen up, breaking any adhesion forced by the glue.
      • Replace the old screen with a new one.
      Pergunte ao FixBot
      Comentar
Conclusão
11 outras pessoas executaram este guia.
Ricky Huitema
Membro desde: 09/24/15
464 Reputação
Autoria de 2 guias
Equipe
Texas Tech, Team 22-5, Rauch Fall 2015 Membro de Texas Tech, Team 22-5, Rauch Fall 2015
TTU-RAUCH-F15S22G5
3 Membros
Autoria de 4 guias
5Comentários do guia
This is not helpful because the one I am working on has no screws.
Matt Brown - Responder Compartilhar
I also have a Split x2 with no screws
dbmacaulay - Responder Compartilhar
I want change my screen because My screen is broken but I do not know , where I can buy my screen
Nohora Chitiva - Responder Compartilhar
ebay or amazon
Andrei Isari - Responder Compartilhar
Is HP Touch Screen Digitizer Glass for HP Split X2 The same as the screen being replaced here?? I need to know
Nwatu Chineme Edger - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 54
Ao todo: 14,075
