Ir para o conteúdo principal
HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement
O que você precisa
  1. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement, Bottom Cover: passo 1, imagem 1 %32 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: passo 2, imagem 1 %32 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: passo 2, imagem 2 %32
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: passo 3, imagem 1 %32 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: passo 3, imagem 2 %32 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: passo 3, imagem 3 %32
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement, Heatsink and Fan Assembly: passo 4, imagem 1 %32 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement, Heatsink and Fan Assembly: passo 4, imagem 2 %32 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement, Heatsink and Fan Assembly: passo 4, imagem 3 %32
    • Use a Phillips #0 Screwdriver to remove the four circled 3 mm screws.
    • Use the same screwdriver to remove the circled 4 mm screw.
  5. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: passo 5, imagem 1 %32 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: passo 5, imagem 2 %32
    • Remove black adhesive tape and metal shielding.
  6. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: passo 6, imagem 1 %32 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: passo 6, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the last 4 mm screw under the black tape.
    • Unplug the cable next to the fan.
  7. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: passo 7, imagem 1 %32 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: passo 7, imagem 2 %32
    • Remove heatsink and fan assembly.
    • Reapply fresh thermal paste to the CPU before placing a heatsink back in the device.
Conclusão
Justin Dages
Membro desde: 03/28/23
361 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 2-5, Harley Spring 2023 Membro de IUPUI, Team 2-5, Harley Spring 2023
IUPUI-HARLEY-S23S2G5
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 15
Duração total: 145
