Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95-
Turn the computer upside down.
Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
Use an opening tool to pry up and loosen the back case from the laptop.
Remove the back case.
Remove the four 2mm Phillips #00 screws securing the battery.
Peel off the adhesive on the left side of the battery holding the speaker wire down.
Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
Carefully unplug the battery by pulling the connector towards the battery.
Remove the battery.
7 outras pessoas executaram este guia.
5 comentários
Thank you! iFixit repair kit made getting the screws out easy. Now have a renewed laptop ready with 6 plus hours of battery life.
Tutoriel parfait, excepté peut-être qu’un double-fil côté droit de la batterie doit être libéré avant de sortir la batterie.
Bravo et merci, ça m’a tout simplement permis de me dépanner seul.
The official HP Manual (http://h10032.www1.hp.com/ctg/Manual/c04...) mentions using Torx T5 to remove the bottom cover.
Thanks! I will correct the step with the right screw size.
