Ir para o conteúdo principal
HP Slate 7 4601 Battery Replacement
O que você precisa
    1. HP Slate 7 4601 Battery Replacement, Battery: passo 1, imagem 1 %32 HP Slate 7 4601 Battery Replacement, Battery: passo 1, imagem 2 %32
      • Begin your replacement by using a T3 or T4 Torx screwdriver.
      • Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
      Pergunte ao FixBot
      Comentar
    2. HP Slate 7 4601 Battery Replacement: passo 2, imagem 1 %32 HP Slate 7 4601 Battery Replacement: passo 2, imagem 2 %32
      • With the pointed end of the spudger, remove the thin metal band.
      • It is easiest to remove the metal band through the headphone opening.
      Pergunte ao FixBot
      Comentar
    3. HP Slate 7 4601 Battery Replacement: passo 3, imagem 1 %32 HP Slate 7 4601 Battery Replacement: passo 3, imagem 2 %32
      • Using the flat end of the spudger, pry back the rear plastic cover.
      • As you work your way around the edge, several "pop" noises will be made. These noises are caused by the plastic clips coming undone.
      Pergunte ao FixBot
      Comentar
    4. HP Slate 7 4601 Battery Replacement: passo 4, imagem 1 %32
      • Remove the rear cover.
      Pergunte ao FixBot
      Comentar
    5. HP Slate 7 4601 Battery Replacement: passo 5, imagem 1 %32
      • Locate and remove the yellow tape covering the red and white speaker wires.
      Pergunte ao FixBot
      Comentar
    6. HP Slate 7 4601 Battery Replacement: passo 6, imagem 1 %32 HP Slate 7 4601 Battery Replacement: passo 6, imagem 2 %32
      • Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
      • Push the same amount on both sides of the connector to avoid jamming or twisting its metal pins.
      • Do not yank or pull on the speaker wires, since they are fragile. Only push on the white connector.
      Pergunte ao FixBot
      Comentar
    7. HP Slate 7 4601 Battery Replacement: passo 7, imagem 1 %32
      • Gently pull back the foil covering the gold charging port ribbon.
      Pergunte ao FixBot
      Comentar
    8. HP Slate 7 4601 Battery Replacement: passo 8, imagem 1 %32 HP Slate 7 4601 Battery Replacement: passo 8, imagem 2 %32
      • Using the flat end of the spudger, lift up the black panel covering the charging port connector.
      • Gently slide the charging port ribbon out from its housing.
      • It may be easier to use the pointed end of the spudger than your fingers.
      Pergunte ao FixBot
      Comentar
    9. HP Slate 7 4601 Battery Replacement: passo 9, imagem 1 %32
      • Lift gold charging strip away from the battery.
      Pergunte ao FixBot
      Comentar
    10. HP Slate 7 4601 Battery Replacement: passo 10, imagem 1 %32 HP Slate 7 4601 Battery Replacement: passo 10, imagem 2 %32
      • Push the white battery connector out of its housing using the pointed end of the spudger.
      Pergunte ao FixBot
      Comentar
    11. HP Slate 7 4601 Battery Replacement: passo 11, imagem 1 %32
      • Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
      • The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
      • The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
      Pergunte ao FixBot
      Comentar
    12. HP Slate 7 4601 Battery Replacement: passo 12, imagem 1 %32
      • Lift battery out of its place and set aside.
      Pergunte ao FixBot
      Comentar
Conclusão
18 outras pessoas executaram este guia.
Zachary
Membro desde: 04/14/14
1.453 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 13-30, Maness Spring 2014 Membro de Cal Poly, Team 13-30, Maness Spring 2014
CPSU-MANESS-S14S13G30
3 Membros
Autoria de 24 guias
4Comentários do guia
Buenas tardes, como están? Consulta, la batería se puede reemplazar por otra genérica, existe algún repuesto?
Javier Sanchez - Responder Compartilhar
Thanx for this amazing demo steps. Sir i need battery of this tab, coz i cant find this battery anywhere then someone told me to go online purchase it wil you so i decided to go online n finally i found ur page so plz arrange me the battery of this tab. My HP Slate 7 battery is not charging . I m from pakistan n my email is aasifbrothers79@gmail.com. Sir i m looking forward for ur kind reply .Thanx
Regards, Asif Sultan
Asif Sultan - Responder Compartilhar
where do i buy the battery in india… there is a site Maxbhi, I ordered the battery, they never send the battery neither returned the money…
Kapil Baidya - Responder Compartilhar
I tried to plug the wrong cable into my HP Prime and have apparently damaged the connection in the calculator. Is there a procedure to repair that connection?
Stuart
Stuart L Filler - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 51
Ao todo: 30,628
