Ir para o conteúdo principal
HP ProBook 645 Keyboard Replacement
O que você precisa
  1. HP ProBook 645 Keyboard Replacement, Remove 2 screws: passo 1, imagem 1 %32
    • Remove the two screws at the two indicated locations with the phillips head screw driver.
    Pergunte ao FixBot
    Comentar
  2. HP ProBook 645 Keyboard Replacement, Flip unit over and open lid.: passo 2, imagem 1 %32
    • Take a spudger tool and pry the keyboard down toward the mouse pad and up toward you. After you raise the keyboard there are tabs at the bottom. Pull the keyboard away from you, and it will dislodge.
    Pergunte ao FixBot
    Comentar
  3. HP ProBook 645 Keyboard Replacement, Ribbon Removal: passo 3, imagem 1 %32
    • 1. Remove ribbon by flipping the black tab up and gently pulling on the ribbon.
    • 2. This ribbon has no tab, gently pull on until it comes loose. To reinsert. Line it up carefully as not to damage the ribbon, and push gently.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Doug
Membro desde: 04/02/15
191 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 42
Ao todo: 4,925
