Ir para o conteúdo principal
HP ProBook 640 G5 RAM Replacement
O que você precisa
    1. HP ProBook 640 G5 RAM Replacement, Back Cover: passo 1, imagem 1 %32
      • Always make sure the HP ProBook 640 G5 is completely powered off and unplugged before beginning this repair. Attempting to open the laptop while it has power may cause electrical damage or personal injury.
      • Shut down the HP ProBook 640 G5 completely.
      • Disconnect the power adapter and all connected peripherals.
      • Press and hold the power button for 5 seconds to discharge remaining electricity.
      Pergunte ao FixBot
      Comentar
    2. HP ProBook 640 G5 RAM Replacement: passo 2, imagem 1 %32
      • Flip the laptop over so the bottom is facing up.
      • Loosen eight silver 6mm screws using a Phillips #0 screwdriver.
      • These screws are captive, so they will loosen but remain attached to the cover.
      • Remove two black 6mm screws using a TR7 Torx screwdriver.
      • Insert a plastic opening tool into the seam and gently pry around the edges.
      • Lift the bottom cover away from the laptop.
      Pergunte ao FixBot
      Comentar
    1. HP ProBook 640 G5 RAM Replacement, RAM: passo 3, imagem 1 %32
      • When replacing RAM, avoid touching the gold contacts and black chips. Handle the stick only by its outer edges or plastic/metal shielding. Touching the chips or gold contacts can introduce static electricity or oil from your fingers, potentially causing damage or poor connectivity.
      • Locate the RAM you intend on replacing/upgrading.
      • Some laptops may come with two sticks of RAM; the one we are working on is equipped with only one.
      Pergunte ao FixBot
      Comentar
    2. HP ProBook 640 G5 RAM Replacement: passo 4, imagem 1 %32
      • Gently push outward on the two retaining clips on each side of the module.
      • The RAM stick will pop up at a 30-degree angle.
      • Hold the RAM module by the edges (avoid touching the gold contacts).
      • Slide it out of the slot at the same angle it popped up.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 29
Ao todo: 168
