Introdução
If you are having trouble booting your laptop, or you would just like to upgrade to more RAM, you may need to replace your RAM card.
Caution - Make sure your laptop is unplugged and powered off before beginning.
O que você precisa
Flip the laptop so the bottom is facing up.
Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
Use a Torx T9 screwdriver to remove the single 6 mm screw.
Loosen the four JIS J1 captive screws on the hard drive tray.
Use the black tab on the hard drive tray and pull it toward the bottom of the laptop to remove the drive.
Use a JIS J1 screwdriver to remove the two 5 mm silver screws securing the hinge covers.
Turn the laptop over and open the top cover.
Use an opening tool to gently pry the plastic hinge covers off both hinges.
Lift the keyboard and pull it gently toward you to remove it from the laptop.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
