Ir para o conteúdo principal
HP ProBook 640 G2 Hard Drive Replacement
O que você precisa
  1. HP ProBook 640 G2 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop so the bottom is facing up.
    • Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
    • Use a Torx T9 screwdriver to remove the single 6 mm screw.
    Pergunte ao FixBot
    Comentar
  2. HP ProBook 640 G2 Hard Drive Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to carefully pry the bottom case.
    • Insert the end of the opening tool into the seam between the bottom and top case and slide it around the perimeter to release the clips.
    • Remove the bottom cover.
    Pergunte ao FixBot
    Comentar
  3. HP ProBook 640 G2 Hard Drive Replacement: passo 3, imagem 1 %32 HP ProBook 640 G2 Hard Drive Replacement: passo 3, imagem 2 %32 HP ProBook 640 G2 Hard Drive Replacement: passo 3, imagem 3 %32
    • Use a JIS J1 screwdriver to remove the seven 6 mm screws securing the battery.
    • Lift the battery from the bottom edge and slide it out of the socket on the motherboard.
    Pergunte ao FixBot
    Comentar
  4. HP ProBook 640 G2 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Loosen the four JIS J1 captive screws on the hard drive tray.
    • Use the black tab on the hard drive tray and pull it toward the bottom of the laptop to remove the drive.
    Pergunte ao FixBot
    Comentar
  5. HP ProBook 640 G2 Hard Drive Replacement: passo 5, imagem 1 %32 HP ProBook 640 G2 Hard Drive Replacement: passo 5, imagem 2 %32 HP ProBook 640 G2 Hard Drive Replacement: passo 5, imagem 3 %32
    • Use the JIS J1 screwdriver to remove the four 3.0 mm screws on the sides of the hard drive tray—two from each side.
    • Remove the old hard drive from the tray.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 61
Ao todo: 263
