Ir para o conteúdo principal
HP ProBook 4540s Optical Drive Replacement
O que você precisa
  1. HP ProBook 4540s Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
    Pergunte ao FixBot
    Comentar
  2. HP ProBook 4540s Optical Drive Replacement, Bottom Door: passo 2, imagem 1 %32
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
    Pergunte ao FixBot
    Comentar
  3. HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: passo 3, imagem 1 %32 HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: passo 3, imagem 2 %32
    • Remove one 6.0 mm Phillips PM2.5x6.0 screw that is securing the optical drive.
    Pergunte ao FixBot
    Comentar
  4. HP ProBook 4540s Optical Drive Replacement: passo 4, imagem 1 %32 HP ProBook 4540s Optical Drive Replacement: passo 4, imagem 2 %32
    • Press the optical drive tab to release the drive component.
    • Gently pull and remove the component from the computer.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Amber Schindler
Membro desde: 10/26/16
1.072 Reputação
Autoria de 6 guias
Equipe
UW Tacoma, Team 1-5, Rose Fall 2016 Membro de UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 30
Ao todo: 2,846
