Ir para o conteúdo principal
HP ProBook 4530s RAM Replacement
    1. HP ProBook 4530s RAM Replacement, Introduction: passo 1, imagem 1 %32
      • Start by flipping the laptop over onto its back.
      Pergunte ao FixBot
      Comentar
    2. HP ProBook 4530s RAM Replacement, Battery Removal: passo 2, imagem 1 %32
      • Press in on both sides, the switches will release the battery.
      • The battery will pop out slightly, allowing you to pull it out.
      Pergunte ao FixBot
      Comentar
    3. HP ProBook 4530s RAM Replacement, Bottom Panel Removal: passo 3, imagem 1 %32
      • Press in on both switches, while pushing onto the plastic panel behind them.
      • The panel should slide out.
      Pergunte ao FixBot
      Comentar
    4. HP ProBook 4530s RAM Replacement, Locate and Disassemble: passo 4, imagem 1 %32 HP ProBook 4530s RAM Replacement, Locate and Disassemble: passo 4, imagem 2 %32 HP ProBook 4530s RAM Replacement, Locate and Disassemble: passo 4, imagem 3 %32
      • Locate the RAM slightly to the center-left.
      • Press outward on the metal retention arms for the RAM.
      • The RAM should pop upward slightly.
      Pergunte ao FixBot
      Comentar
    5. HP ProBook 4530s RAM Replacement, RAM Removal: passo 5, imagem 1 %32
      • Grab the RAM gently and remove at a 45 Degree angle.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Drew Canada
Membro desde: 04/03/18
1.490 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 46
Ao todo: 3,782
