Ir para o conteúdo principal
HP ProBook 4520s Screen Replacement
O que você precisa
  1. HP ProBook 4520s Screen Replacement, Battery: passo 1, imagem 1 %32 HP ProBook 4520s Screen Replacement, Battery: passo 1, imagem 2 %32
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
    Pergunte ao FixBot
    Comentar
  2. HP ProBook 4520s Screen Replacement: passo 2, imagem 1 %32
    • Remove the battery by holding the latches and sliding the battery away from you.
    Pergunte ao FixBot
    Comentar
  3. HP ProBook 4520s Screen Replacement, Switch Cover: passo 3, imagem 1 %32 HP ProBook 4520s Screen Replacement, Switch Cover: passo 3, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
    Pergunte ao FixBot
    Comentar
  4. HP ProBook 4520s Screen Replacement: passo 4, imagem 1 %32 HP ProBook 4520s Screen Replacement: passo 4, imagem 2 %32
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
    Pergunte ao FixBot
    Comentar
  5. HP ProBook 4520s Screen Replacement: passo 5, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
    Pergunte ao FixBot
    Comentar
  6. HP ProBook 4520s Screen Replacement: passo 6, imagem 1 %32 HP ProBook 4520s Screen Replacement: passo 6, imagem 2 %32 HP ProBook 4520s Screen Replacement: passo 6, imagem 3 %32
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
    Pergunte ao FixBot
    Comentar
  7. HP ProBook 4520s Screen Replacement, Screen: passo 7, imagem 1 %32 HP ProBook 4520s Screen Replacement, Screen: passo 7, imagem 2 %32
    • Use a metal spudger to remove four rubber caps at the bottom of the screen border.
    Pergunte ao FixBot
    Comentar
  8. HP ProBook 4520s Screen Replacement: passo 8, imagem 1 %32 HP ProBook 4520s Screen Replacement: passo 8, imagem 2 %32
    • Use a Torx (T9) head screwdriver to remove the four 5mm screws beneath the rubber caps.
    Pergunte ao FixBot
    Comentar
  9. HP ProBook 4520s Screen Replacement: passo 9, imagem 1 %32 HP ProBook 4520s Screen Replacement: passo 9, imagem 2 %32 HP ProBook 4520s Screen Replacement: passo 9, imagem 3 %32
    • Pry open the tabs behind the border of the screen using a metal spudger.
    • Set the border of the screen aside.
    Pergunte ao FixBot
    Comentar
  10. HP ProBook 4520s Screen Replacement: passo 10, imagem 1 %32 HP ProBook 4520s Screen Replacement: passo 10, imagem 2 %32
    • Use a Torx (T9) head screwdriver to remove two 5mm screws above the screen, and two more screws below it.
    • The bottom set of screws is installed on the innermost screw holes.
    Pergunte ao FixBot
    Comentar
  11. HP ProBook 4520s Screen Replacement: passo 11, imagem 1 %32
    • Above the screen is a bronze port with a cable connected to it. Disconnect the cable using a metal spudger or your finger.
    Pergunte ao FixBot
    Comentar
  12. HP ProBook 4520s Screen Replacement: passo 12, imagem 1 %32
    • Gently push the back cover away.
    Pergunte ao FixBot
    Comentar
  13. HP ProBook 4520s Screen Replacement: passo 13, imagem 1 %32 HP ProBook 4520s Screen Replacement: passo 13, imagem 2 %32 HP ProBook 4520s Screen Replacement: passo 13, imagem 3 %32
    • Use a Phillips (PH1) head screwdriver to remove eight 2mm screws from the screen. Four of the screws will be on the left side and four will be on the right.
    • Place the screen face down.
    Pergunte ao FixBot
    Comentar
  14. HP ProBook 4520s Screen Replacement: passo 14, imagem 1 %32 HP ProBook 4520s Screen Replacement: passo 14, imagem 2 %32 HP ProBook 4520s Screen Replacement: passo 14, imagem 3 %32
    • Peel the ribbon cable away from the screen.
    Pergunte ao FixBot
    Comentar
  15. HP ProBook 4520s Screen Replacement: passo 15, imagem 1 %32 HP ProBook 4520s Screen Replacement: passo 15, imagem 2 %32
    • To open the clamp for the ribbon cable, use a spudger to pry up the metal bar securing it to the screen.
    • Disconnect the cable after freeing it from the metal bar
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Equipe
UC Davis, Team 1-3, Oliver Fall 2016 Membro de UC Davis, Team 1-3, Oliver Fall 2016
UCD-OLIVER-F16S1G3
5 Membros
Autoria de 8 guias
2Comentários do guia
I need back cover hp i5 probook 4520s
amir86216 - Responder Compartilhar
I need speakers hp probook 4520s i5
Osagie Rmd - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 62
Ao todo: 6,985
