Ir para o conteúdo principal
HP ProBook 450 G4 Keyboard Replacement
O que você precisa
  1. HP ProBook 450 G4 Keyboard Replacement, Hard Drive: passo 1, imagem 1 %32 HP ProBook 450 G4 Keyboard Replacement, Hard Drive: passo 1, imagem 2 %32
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
    Pergunte ao FixBot
    Comentar
  2. HP ProBook 450 G4 Keyboard Replacement: passo 2, imagem 1 %32 HP ProBook 450 G4 Keyboard Replacement: passo 2, imagem 2 %32 HP ProBook 450 G4 Keyboard Replacement: passo 2, imagem 3 %32
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
    Pergunte ao FixBot
    Comentar
  3. HP ProBook 450 G4 Keyboard Replacement: passo 3, imagem 1 %32 HP ProBook 450 G4 Keyboard Replacement: passo 3, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
    Pergunte ao FixBot
    Comentar
  4. HP ProBook 450 G4 Keyboard Replacement: passo 4, imagem 1 %32 HP ProBook 450 G4 Keyboard Replacement: passo 4, imagem 2 %32
    • Use the spudger to lift the left side of the hard drive up.
    • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
    Pergunte ao FixBot
    Comentar
  5. HP ProBook 450 G4 Keyboard Replacement, Keyboard: passo 5, imagem 1 %32 HP ProBook 450 G4 Keyboard Replacement, Keyboard: passo 5, imagem 2 %32 HP ProBook 450 G4 Keyboard Replacement, Keyboard: passo 5, imagem 3 %32
    • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
    • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
    Pergunte ao FixBot
    Comentar
  6. HP ProBook 450 G4 Keyboard Replacement: passo 6, imagem 1 %32 HP ProBook 450 G4 Keyboard Replacement: passo 6, imagem 2 %32 HP ProBook 450 G4 Keyboard Replacement: passo 6, imagem 3 %32
    • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
    • Apply pressure to the black tabs until they release and pop out.
    Pergunte ao FixBot
    Comentar
  7. HP ProBook 450 G4 Keyboard Replacement: passo 7, imagem 1 %32 HP ProBook 450 G4 Keyboard Replacement: passo 7, imagem 2 %32 HP ProBook 450 G4 Keyboard Replacement: passo 7, imagem 3 %32
    • Orient the laptop so the keyboard is facing upwards and towards you.
    • Insert the spudger in between the edge of the keyboard and the computer frame.
    • Slide the spudger around the edge of the keyboard until the keyboard is loose.
    • Gently pull the keyboard away from the body of the laptop.
    • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
    Pergunte ao FixBot
    Comentar
  8. HP ProBook 450 G4 Keyboard Replacement: passo 8, imagem 1 %32 HP ProBook 450 G4 Keyboard Replacement: passo 8, imagem 2 %32
    • Use a spudger to gently lift up the black locking bar on the keyboard connector.
    • Slide the keyboard ribbon out of the connector.
    • Remove the keyboard.
    • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Sebastian Dow
Membro desde: 01/23/20
1.127 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S1-G3, White Winter 2020 Membro de Cal Poly, Team S1-G3, White Winter 2020
CPSU-WHITE-W20S1G3
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 108
Ao todo: 9,884
