Ir para o conteúdo principal
HP ProBook 450 G4 Battery Replacement
O que você precisa
    1. HP ProBook 450 G4 Battery Replacement, Hard Drive: passo 1, imagem 1 %32 HP ProBook 450 G4 Battery Replacement, Hard Drive: passo 1, imagem 2 %32
      • Power your laptop off.
      • Flip the laptop over.
      • Orient the laptop so the two vents on the bottom face upward and are further away from you.
      Pergunte ao FixBot
      Comentar
    2. HP ProBook 450 G4 Battery Replacement: passo 2, imagem 1 %32 HP ProBook 450 G4 Battery Replacement: passo 2, imagem 2 %32 HP ProBook 450 G4 Battery Replacement: passo 2, imagem 3 %32
      • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
      • Use the spudger to separate the vent panel from the laptop.
      • Slide the vent panel off the backside of the laptop.
      Pergunte ao FixBot
      Comentar
    3. HP ProBook 450 G4 Battery Replacement: passo 3, imagem 1 %32 HP ProBook 450 G4 Battery Replacement: passo 3, imagem 2 %32
      • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
      Pergunte ao FixBot
      Comentar
    4. HP ProBook 450 G4 Battery Replacement: passo 4, imagem 1 %32 HP ProBook 450 G4 Battery Replacement: passo 4, imagem 2 %32
      • Use the spudger to lift the left side of the hard drive up.
      • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
      Pergunte ao FixBot
      Comentar
    1. HP ProBook 450 G4 Battery Replacement, Keyboard: passo 5, imagem 1 %32 HP ProBook 450 G4 Battery Replacement, Keyboard: passo 5, imagem 2 %32 HP ProBook 450 G4 Battery Replacement, Keyboard: passo 5, imagem 3 %32
      • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
      • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
      Pergunte ao FixBot
      Comentar
    2. HP ProBook 450 G4 Battery Replacement: passo 6, imagem 1 %32 HP ProBook 450 G4 Battery Replacement: passo 6, imagem 2 %32 HP ProBook 450 G4 Battery Replacement: passo 6, imagem 3 %32
      • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
      • Apply pressure to the black tabs until they release and pop out.
      Pergunte ao FixBot
      Comentar
    3. HP ProBook 450 G4 Battery Replacement: passo 7, imagem 1 %32 HP ProBook 450 G4 Battery Replacement: passo 7, imagem 2 %32 HP ProBook 450 G4 Battery Replacement: passo 7, imagem 3 %32
      • Orient the laptop so the keyboard is facing upwards and towards you.
      • Insert the spudger in between the edge of the keyboard and the computer frame.
      • Slide the spudger around the edge of the keyboard until the keyboard is loose.
      • Gently pull the keyboard away from the body of the laptop.
      • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
      Pergunte ao FixBot
      Comentar
    4. HP ProBook 450 G4 Battery Replacement: passo 8, imagem 1 %32 HP ProBook 450 G4 Battery Replacement: passo 8, imagem 2 %32
      • Use a spudger to gently lift up the black locking bar on the keyboard connector.
      • Slide the keyboard ribbon out of the connector.
      • Remove the keyboard.
      • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
      Pergunte ao FixBot
      Comentar
    1. HP ProBook 450 G4 Battery Replacement, Battery: passo 9, imagem 1 %32 HP ProBook 450 G4 Battery Replacement, Battery: passo 9, imagem 2 %32
      • Flip the laptop back over.
      • Remove the eight 6.8mm T8 Torx screws on the backside of the laptop.
      Pergunte ao FixBot
      Comentar
    2. HP ProBook 450 G4 Battery Replacement: passo 10, imagem 1 %32 HP ProBook 450 G4 Battery Replacement: passo 10, imagem 2 %32
      • Use a Phillips #0 screwdriver to remove the three 6.6mm screws from the upper left corner of the laptop.
      Pergunte ao FixBot
      Comentar
    3. HP ProBook 450 G4 Battery Replacement: passo 11, imagem 1 %32 HP ProBook 450 G4 Battery Replacement: passo 11, imagem 2 %32
      • Use the spudger to slide the disk drive out of the laptop.
      • Use the Phillips #0 screwdriver to remove the two 3.2mm screws that are underneath where the disk drive previously was.
      Pergunte ao FixBot
      Comentar
    4. HP ProBook 450 G4 Battery Replacement: passo 12, imagem 1 %32 HP ProBook 450 G4 Battery Replacement: passo 12, imagem 2 %32 HP ProBook 450 G4 Battery Replacement: passo 12, imagem 3 %32
      • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
      Pergunte ao FixBot
      Comentar
    5. HP ProBook 450 G4 Battery Replacement: passo 13, imagem 1 %32 HP ProBook 450 G4 Battery Replacement: passo 13, imagem 2 %32
      • Flip the laptop back over so it is facing upwards.
      • Remove the six 6.6mm T8 Torx screws underneath where the keyboard used to be.
      Pergunte ao FixBot
      Comentar
    6. HP ProBook 450 G4 Battery Replacement: passo 14, imagem 1 %32 HP ProBook 450 G4 Battery Replacement: passo 14, imagem 2 %32 HP ProBook 450 G4 Battery Replacement: passo 14, imagem 3 %32
      • Use the spudger to disconnect the nine cable connectors that secure the top case of the laptop to the body of the laptop.
      • Be extra careful while disconnecting the cable connectors because they can tear easily.
      Pergunte ao FixBot
      Comentar
    7. HP ProBook 450 G4 Battery Replacement: passo 15, imagem 1 %32 HP ProBook 450 G4 Battery Replacement: passo 15, imagem 2 %32
      • Insert the spudger in between the top case of the laptop and its outer frame.
      • Slide the spudger around the edge of the laptop until the top case comes off.
      • Remove the top case.
      Pergunte ao FixBot
      Comentar
    8. HP ProBook 450 G4 Battery Replacement: passo 16, imagem 1 %32 HP ProBook 450 G4 Battery Replacement: passo 16, imagem 2 %32
      • Insert the opening tool underneath the left side of the battery to remove it from the laptop.
      Pergunte ao FixBot
      Comentar
Conclusão
10 outras pessoas executaram este guia.
Sebastian Dow
Membro desde: 01/23/20
1.127 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S1-G3, White Winter 2020 Membro de Cal Poly, Team S1-G3, White Winter 2020
CPSU-WHITE-W20S1G3
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 47
Últimos 30 dias: 155
Ao todo: 25,206
