Ir para o conteúdo principal
HP ProBook 440 G1 Keyboard Replacement
O que você precisa
  1. HP ProBook 440 G1 Keyboard Replacement, Battery: passo 1, imagem 1 %32 HP ProBook 440 G1 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
    Pergunte ao FixBot
    Comentar
  2. HP ProBook 440 G1 Keyboard Replacement: passo 2, imagem 1 %32 HP ProBook 440 G1 Keyboard Replacement: passo 2, imagem 2 %32
    • Pull the battery out.
    Pergunte ao FixBot
    Comentar
  3. HP ProBook 440 G1 Keyboard Replacement, Backplate: passo 3, imagem 1 %32 HP ProBook 440 G1 Keyboard Replacement, Backplate: passo 3, imagem 2 %32 HP ProBook 440 G1 Keyboard Replacement, Backplate: passo 3, imagem 3 %32
    • Push and hold the release tabs on the right and left toward the center again.
    Pergunte ao FixBot
    Comentar
  4. HP ProBook 440 G1 Keyboard Replacement: passo 4, imagem 1 %32
    • Slide the backplate off.
    Pergunte ao FixBot
    Comentar
  5. HP ProBook 440 G1 Keyboard Replacement, Keyboard: passo 5, imagem 1 %32 HP ProBook 440 G1 Keyboard Replacement, Keyboard: passo 5, imagem 2 %32
    • Locate the two screws on the back of the laptop, holding the keyboard.
    • Remove the two screws using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. HP ProBook 440 G1 Keyboard Replacement: passo 6, imagem 1 %32
    • Flip the computer over so as to see the keyboard.
    Pergunte ao FixBot
    Comentar
  7. HP ProBook 440 G1 Keyboard Replacement: passo 7, imagem 1 %32 HP ProBook 440 G1 Keyboard Replacement: passo 7, imagem 2 %32
    • Place both hands on the keyboard and slide it back.
    • The keyboard will only slide back a small amount.
    Pergunte ao FixBot
    Comentar
  8. HP ProBook 440 G1 Keyboard Replacement: passo 8, imagem 1 %32 HP ProBook 440 G1 Keyboard Replacement: passo 8, imagem 2 %32
    • Using a plastic opening tool, pull the keyboard up.
    Pergunte ao FixBot
    Comentar
  9. HP ProBook 440 G1 Keyboard Replacement: passo 9, imagem 1 %32 HP ProBook 440 G1 Keyboard Replacement: passo 9, imagem 2 %32 HP ProBook 440 G1 Keyboard Replacement: passo 9, imagem 3 %32
    • Locate the connector strip between the keyboard and the laptop.
    • Pull the strip away from the connector until it unplugs.
    • It may take some force to make the strip disconnect.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
thanks for that
sir i want original keyboard 440 G1
if u dont mine suggest me
karun kumar - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 55
Ao todo: 2,835
