Ir para o conteúdo principal
HP ProBook 4320t Touchpad Panel Replacement Guide
O que você precisa
  1. HP ProBook 4320t Touchpad Panel Replacement Guide, Battery Removal: passo 1, imagem 1 %32 HP ProBook 4320t Touchpad Panel Replacement Guide, Battery Removal: passo 1, imagem 2 %32
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
    Pergunte ao FixBot
    Comentar
  2. HP ProBook 4320t Touchpad Panel Replacement Guide, Screws: passo 2, imagem 1 %32 HP ProBook 4320t Touchpad Panel Replacement Guide, Screws: passo 2, imagem 2 %32
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
    Pergunte ao FixBot
    Comentar
  3. HP ProBook 4320t Touchpad Panel Replacement Guide, Flip: passo 3, imagem 1 %32
    • Flip laptop over and open it.
    Pergunte ao FixBot
    Comentar
  4. HP ProBook 4320t Touchpad Panel Replacement Guide, Push N Lift: passo 4, imagem 1 %32
    • Slightly push up while lifting up on the power button panel to release the panel.
    Pergunte ao FixBot
    Comentar
  5. HP ProBook 4320t Touchpad Panel Replacement Guide, Unscrewing: passo 5, imagem 1 %32
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
    Pergunte ao FixBot
    Comentar
  6. HP ProBook 4320t Touchpad Panel Replacement Guide, Careful Now: passo 6, imagem 1 %32 HP ProBook 4320t Touchpad Panel Replacement Guide, Careful Now: passo 6, imagem 2 %32
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
    Pergunte ao FixBot
    Comentar
  7. HP ProBook 4320t Touchpad Panel Replacement Guide, Disconnect Wire: passo 7, imagem 1 %32
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
    Pergunte ao FixBot
    Comentar
  8. HP ProBook 4320t Touchpad Panel Replacement Guide, Unscrew: passo 8, imagem 1 %32
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
    Pergunte ao FixBot
    Comentar
  9. HP ProBook 4320t Touchpad Panel Replacement Guide, Slide the Panel Off: passo 9, imagem 1 %32
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
    Pergunte ao FixBot
    Comentar
  10. HP ProBook 4320t Touchpad Panel Replacement Guide, Lift up Carefully: passo 10, imagem 1 %32
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
    Pergunte ao FixBot
    Comentar
  11. HP ProBook 4320t Touchpad Panel Replacement Guide, Disconnect Wire: passo 11, imagem 1 %32
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
    Pergunte ao FixBot
    Comentar
Conclusão
Joshua
Membro desde: 09/23/14
134 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 9-5, Blackwell Fall 2014 Membro de USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 21
Ao todo: 632
