Ir para o conteúdo principal
HP ProBook 4320t Keyboard Replacement Guide
O que você precisa
  1. HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: passo 1, imagem 1 %32 HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: passo 1, imagem 2 %32
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
    Pergunte ao FixBot
    Comentar
  2. HP ProBook 4320t Keyboard Replacement Guide, Screws: passo 2, imagem 1 %32 HP ProBook 4320t Keyboard Replacement Guide, Screws: passo 2, imagem 2 %32
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
    Pergunte ao FixBot
    Comentar
  3. HP ProBook 4320t Keyboard Replacement Guide, Flip: passo 3, imagem 1 %32
    • Flip laptop over and open it.
    Pergunte ao FixBot
    Comentar
  4. HP ProBook 4320t Keyboard Replacement Guide, Push N Lift: passo 4, imagem 1 %32
    • Slightly push up while lifting up on the power button panel to release the panel.
    Pergunte ao FixBot
    Comentar
  5. HP ProBook 4320t Keyboard Replacement Guide, Unscrewing: passo 5, imagem 1 %32
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
    Pergunte ao FixBot
    Comentar
  6. HP ProBook 4320t Keyboard Replacement Guide, Careful Now: passo 6, imagem 1 %32 HP ProBook 4320t Keyboard Replacement Guide, Careful Now: passo 6, imagem 2 %32
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
    Pergunte ao FixBot
    Comentar
  7. HP ProBook 4320t Keyboard Replacement Guide, Disconnect Wire: passo 7, imagem 1 %32
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
    Pergunte ao FixBot
    Comentar
Conclusão
Joshua
Membro desde: 09/23/14
134 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 9-5, Blackwell Fall 2014 Membro de USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 33
Ao todo: 1,259
