Ir para o conteúdo principal
HP Pavilion ze5000 Screen Replacement
O que você precisa
  1. HP Pavilion ze5000 Screen Replacement, Screen: passo 1, imagem 1 %32 HP Pavilion ze5000 Screen Replacement, Screen: passo 1, imagem 2 %32 HP Pavilion ze5000 Screen Replacement, Screen: passo 1, imagem 3 %32
    • Remove two 5.0 mm Philips #0 screws on the hinge of the device
    Pergunte ao FixBot
    Comentar
  2. HP Pavilion ze5000 Screen Replacement: passo 2, imagem 1 %32 HP Pavilion ze5000 Screen Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, gently pull on the hinges to remove the plastic case connected to the hinges
    Pergunte ao FixBot
    Comentar
  3. HP Pavilion ze5000 Screen Replacement: passo 3, imagem 1 %32 HP Pavilion ze5000 Screen Replacement: passo 3, imagem 2 %32 HP Pavilion ze5000 Screen Replacement: passo 3, imagem 3 %32
    • Remove the connection between the plastic case and interior of the device
    Pergunte ao FixBot
    Comentar
  4. HP Pavilion ze5000 Screen Replacement: passo 4, imagem 1 %32 HP Pavilion ze5000 Screen Replacement: passo 4, imagem 2 %32 HP Pavilion ze5000 Screen Replacement: passo 4, imagem 3 %32
    • Remove the connection from the exposed hinge and interior of the device
    Pergunte ao FixBot
    Comentar
  5. HP Pavilion ze5000 Screen Replacement: passo 5, imagem 1 %32 HP Pavilion ze5000 Screen Replacement: passo 5, imagem 2 %32
    • Remove the 3.5 mm philips #00 screw on the small circuit board on the hinge
    Pergunte ao FixBot
    Comentar
  6. HP Pavilion ze5000 Screen Replacement: passo 6, imagem 1 %32 HP Pavilion ze5000 Screen Replacement: passo 6, imagem 2 %32
    • Remove the 5.0 mm philips #0 screw that was hidden underneath the small circuit board
    Pergunte ao FixBot
    Comentar
  7. HP Pavilion ze5000 Screen Replacement: passo 7, imagem 1 %32
    • Remove the 6 plastic caps located in the four corners of the screen and the top of the screen
    • It may be easier to use tweezers for this part
    Pergunte ao FixBot
    Comentar
  8. HP Pavilion ze5000 Screen Replacement: passo 8, imagem 1 %32 HP Pavilion ze5000 Screen Replacement: passo 8, imagem 2 %32 HP Pavilion ze5000 Screen Replacement: passo 8, imagem 3 %32
    • Unscrew the six 5.0 mm Philips #0 screws underneath the caps
    Pergunte ao FixBot
    Comentar
  9. HP Pavilion ze5000 Screen Replacement: passo 9, imagem 1 %32 HP Pavilion ze5000 Screen Replacement: passo 9, imagem 2 %32 HP Pavilion ze5000 Screen Replacement: passo 9, imagem 3 %32
    • Using a spudger, pry the plastic casing off of the screen.
    Pergunte ao FixBot
    Comentar
  10. HP Pavilion ze5000 Screen Replacement: passo 10, imagem 1 %32 HP Pavilion ze5000 Screen Replacement: passo 10, imagem 2 %32 HP Pavilion ze5000 Screen Replacement: passo 10, imagem 3 %32
    • Remove four 5.0 mm Philips #0 screws located in the corners of the screen
    • These screws locations will be close to the screws locations in step 2.
    • During reassembly, make sure you do not confuse the proper screw placements from this step and step 4.
    Pergunte ao FixBot
    Comentar
  11. HP Pavilion ze5000 Screen Replacement: passo 11, imagem 1 %32 HP Pavilion ze5000 Screen Replacement: passo 11, imagem 2 %32
    • Remove the four 3.5 mm Philips #00 screws from the sides of the aluminum casing.
    • There will be two 3.5 mm Philips screws on each side
    Pergunte ao FixBot
    Comentar
Conclusão
Eric Beaudry
Membro desde: 03/06/18
823 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 28
Ao todo: 464
