Ir para o conteúdo principal
HP Pavilion tx2500 Fan Replacement
O que você precisa
  1. HP Pavilion tx2500 Fan  Replacement, Screen Rotator: passo 1, imagem 1 %32
    • Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
    Pergunte ao FixBot
    Comentar
  2. HP Pavilion tx2500 Fan  Replacement: passo 2, imagem 1 %32 HP Pavilion tx2500 Fan  Replacement: passo 2, imagem 2 %32
    • Squeeze the latches on the battery until you hear a click. Slide out the battery.
    Pergunte ao FixBot
    Comentar
  3. HP Pavilion tx2500 Fan  Replacement: passo 3, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the 4.5 mm screw from the WLAN model screen.
    • Once unscrewed, lift the right side of the WLAN module compartment cover and swing it to the left.
    Pergunte ao FixBot
    Comentar
  4. HP Pavilion tx2500 Fan  Replacement: passo 4, imagem 1 %32
    • Using the plastic opening tool, disconnect the WLAN antenna cables from the WLAN module.
    Pergunte ao FixBot
    Comentar
  5. HP Pavilion tx2500 Fan  Replacement: passo 5, imagem 1 %32
    • Using the Phillips #0 screwdriver, unscrew the 4.5 mm screw from the middle section in the battery compartment.
    Pergunte ao FixBot
    Comentar
  6. HP Pavilion tx2500 Fan  Replacement: passo 6, imagem 1 %32
    • Use the plastic opening tool to disconnect the wires in the upper corners.
    Pergunte ao FixBot
    Comentar
  7. HP Pavilion tx2500 Fan  Replacement: passo 7, imagem 1 %32
    • Flip the laptop front side up and then use your fingers to lift up the keyboard.
    Pergunte ao FixBot
    Comentar
  8. HP Pavilion tx2500 Fan  Replacement: passo 8, imagem 1 %32
    • Lift up the black latch that connects the film strip to the base of the computer.
    • Use the plastic opening tool to disconnect the film strip from the base of the computer.
    Pergunte ao FixBot
    Comentar
  9. HP Pavilion tx2500 Fan  Replacement: passo 9, imagem 1 %32 HP Pavilion tx2500 Fan  Replacement: passo 9, imagem 2 %32
    • Rotate the screen 90 degrees and remove the base under the screen.
    Pergunte ao FixBot
    Comentar
  10. HP Pavilion tx2500 Fan  Replacement: passo 10, imagem 1 %32
    • Rotate the screen back towards you.
    • Lift up the convertible hinge to unclip it from the base of the computer.
    Pergunte ao FixBot
    Comentar
  11. HP Pavilion tx2500 Fan  Replacement: passo 11, imagem 1 %32 HP Pavilion tx2500 Fan  Replacement: passo 11, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove both of the 5.0 mm screws on the base of the rotator.
    Pergunte ao FixBot
    Comentar
  12. HP Pavilion tx2500 Fan  Replacement: passo 12, imagem 1 %32
    • Gently lift up and remove the screen.
    Pergunte ao FixBot
    Comentar
  13. HP Pavilion tx2500 Fan  Replacement, Fan: passo 13, imagem 1 %32 HP Pavilion tx2500 Fan  Replacement, Fan: passo 13, imagem 2 %32 HP Pavilion tx2500 Fan  Replacement, Fan: passo 13, imagem 3 %32
    • Disconnect the wire from the system board using the plastic opening tool.
    • Disconnect the wire from the optical drive using the plastic opening tool.
    • Gently lift the top cover from the tablet.
    Pergunte ao FixBot
    Comentar
  14. HP Pavilion tx2500 Fan  Replacement: passo 14, imagem 1 %32 HP Pavilion tx2500 Fan  Replacement: passo 14, imagem 2 %32
    • Using the plastic opening tool, disconnect the plastic blue film from the tablet.
    • Disconnect the wire using the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  15. HP Pavilion tx2500 Fan  Replacement: passo 15, imagem 1 %32 HP Pavilion tx2500 Fan  Replacement: passo 15, imagem 2 %32
    • Lift the system board from the tablet.
    • Turn the system board over and lay it flat on a soft surface.
    Pergunte ao FixBot
    Comentar
  16. HP Pavilion tx2500 Fan  Replacement: passo 16, imagem 1 %32 HP Pavilion tx2500 Fan  Replacement: passo 16, imagem 2 %32
    • Using a Phillips #00, remove the 4.5 mm screws that connect the fan to the board.
    • Using a plastic opening tool, disconnect the wire that attached the fan to the board.
    Pergunte ao FixBot
    Comentar
  17. HP Pavilion tx2500 Fan  Replacement: passo 17, imagem 1 %32
    • Gently lift the fan away from the board.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ricardo
Membro desde: 10/13/15
164 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 1,210
