Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The motherboard is the meat of your device. Almost everything on the inside such as the fan, mouse pad, and speakers, are all attached. Although the removal and replacement of this component is not difficult, it should be done cautiously.
O que você precisa
Unscrew the two screws JIS #0 located on opposites sides of the panel.
Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
