Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Slide pill shaped tab to the other side of the channel.
Unscrew the two screws JIS #0 located on opposites sides of the panel.
Pull out and unplug the tab on the right hand side.
Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
Remove 3 screws located where the battery previously was.
Remove 6 screws located under the spot where the smaller L-shaped panel was located.
In lower left hand corner, pull on black tab to unplug the disc drive.
In upper left hand corner, unplug the large black electrical tape covered laptop plug.
