Ir para o conteúdo principal
HP Pavilion dv4000 Keyboard Replacement
O que você precisa
    1. HP Pavilion dv4000 Keyboard Replacement, Battery: passo 1, imagem 1 %32
      • Turn the laptop upside down with the battery compartment facing you.
      Pergunte ao FixBot
      Comentar
    2. HP Pavilion dv4000 Keyboard Replacement: passo 2, imagem 1 %32
      • Slide the battery release latch to the right and hold in place.
      Pergunte ao FixBot
      Comentar
    3. HP Pavilion dv4000 Keyboard Replacement: passo 3, imagem 1 %32
      • Lift the front edge of the battery up and remove it from the compartment.
      Pergunte ao FixBot
      Comentar
    1. HP Pavilion dv4000 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
      • Have your device open in front of you for easy access to the keyboard.
      Pergunte ao FixBot
      Comentar
    2. HP Pavilion dv4000 Keyboard Replacement: passo 5, imagem 1 %32
      • Using a metal spudger, pry up on the plastic piece above the keyboard containing the power button.
      • Be careful not to damage any components with the tool while prying.
      Pergunte ao FixBot
      Comentar
    3. HP Pavilion dv4000 Keyboard Replacement: passo 6, imagem 1 %32
      • Lift the plastic piece up.
      • When lifting this piece, be careful not to damage the ribbon strip connected to it.
      Pergunte ao FixBot
      Comentar
    4. HP Pavilion dv4000 Keyboard Replacement: passo 7, imagem 1 %32 HP Pavilion dv4000 Keyboard Replacement: passo 7, imagem 2 %32 HP Pavilion dv4000 Keyboard Replacement: passo 7, imagem 3 %32
      • Place the plastic piece on the keyboard so the ribbon strip is easily accessible.
      • Carefully disconnect the ribbon strip from the keyboard by pressing on the tabs at the edges.
      • Remove plastic piece and set aside.
      Pergunte ao FixBot
      Comentar
    5. HP Pavilion dv4000 Keyboard Replacement: passo 8, imagem 1 %32
      • Locate the four 2x2 mm screws that hold the keyboard in place.
      Pergunte ao FixBot
      Comentar
    6. HP Pavilion dv4000 Keyboard Replacement: passo 9, imagem 1 %32
      • Unscrew the four 2x2 mm screws with a #00 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    7. HP Pavilion dv4000 Keyboard Replacement: passo 10, imagem 1 %32 HP Pavilion dv4000 Keyboard Replacement: passo 10, imagem 2 %32
      • Lift the keyboard up.
      • When lifting the keyboard, be sure not to damage the ribbon strip that is connected to it.
      Pergunte ao FixBot
      Comentar
    8. HP Pavilion dv4000 Keyboard Replacement: passo 11, imagem 1 %32
      • Locate where the ribbon strip is connected to the motherboard.
      Pergunte ao FixBot
      Comentar
    9. HP Pavilion dv4000 Keyboard Replacement: passo 12, imagem 1 %32 HP Pavilion dv4000 Keyboard Replacement: passo 12, imagem 2 %32
      • Pry at the edges of the plastic clip holding the ribbon cable to the motherboard.
      • Be careful during this step as these clips are very easy to break.
      Pergunte ao FixBot
      Comentar
    10. HP Pavilion dv4000 Keyboard Replacement: passo 13, imagem 1 %32 HP Pavilion dv4000 Keyboard Replacement: passo 13, imagem 2 %32 HP Pavilion dv4000 Keyboard Replacement: passo 13, imagem 3 %32
      • Remove the keyboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Nick LaMarche
Membro desde: 10/18/16
373 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-2, Catania Fall 2016 Membro de UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 15
Ao todo: 1,264
