Ir para o conteúdo principal
HP Pavilion dv4000 Heat Sink Replacement
O que você precisa
  1. HP Pavilion dv4000 Heat Sink Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Heat Sink Replacement: passo 2, imagem 1 %32
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Heat Sink Replacement: passo 3, imagem 1 %32
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Heat Sink Replacement, Heat Sink: passo 4, imagem 1 %32
    • Position laptop with heat sink compartment facing you.
    • Locate the one 2x5 mm Torx screw.
  5. HP Pavilion dv4000 Heat Sink Replacement: passo 5, imagem 1 %32
    • Remove the one 2x5 mm Torx screw securing the thermal cover with a #6 Torx screwdriver.
  6. HP Pavilion dv4000 Heat Sink Replacement: passo 6, imagem 1 %32 HP Pavilion dv4000 Heat Sink Replacement: passo 6, imagem 2 %32
    • Lift thermal cover to reveal heat sink.
    • Remove and set aside thermal cover.
  7. HP Pavilion dv4000 Heat Sink Replacement: passo 7, imagem 1 %32 HP Pavilion dv4000 Heat Sink Replacement: passo 7, imagem 2 %32
    • Locate the four screws on each corner of heat sink.
    • Unscrew the four 2x12 mm screws with a #00 Phillips screwdriver.
  8. HP Pavilion dv4000 Heat Sink Replacement: passo 8, imagem 1 %32 HP Pavilion dv4000 Heat Sink Replacement: passo 8, imagem 2 %32
    • Grab sides of heat sink and carefully lift from compartment.
    • Due to adhesive bonding of heat sink to base, wiggling it side to side before lifting might help removal process.
  9. HP Pavilion dv4000 Heat Sink Replacement: passo 9, imagem 1 %32
    • To reapply thermal paste, check out iFixit's guide here.
Conclusão
Equipe
UMass Dartmouth, Team 4-2, Catania Fall 2016 Membro de UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 580
