Ir para o conteúdo principal
HP Pavilion N3350 RAM Replacement
O que você precisa
  1. HP Pavilion N3350 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Locate the RAM on the bottom side of the laptop, the cover is secured by a 6 millimeter screw. Remove this with a Philips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. HP Pavilion N3350 RAM Replacement: passo 2, imagem 1 %32
    • Underneath are the RAM boards. They are secured by two plastic clips each. Locate these to continue removal.
    Pergunte ao FixBot
    Comentar
  3. HP Pavilion N3350 RAM Replacement: passo 3, imagem 1 %32
    • Place your thumbs on two of the clips securing one board. Push outwards on the clips. This should pop the board up.
    Pergunte ao FixBot
    Comentar
  4. HP Pavilion N3350 RAM Replacement: passo 4, imagem 1 %32
    • Repeat on second board. When both are released, they should appear as they do in the picture.
    Pergunte ao FixBot
    Comentar
  5. HP Pavilion N3350 RAM Replacement: passo 5, imagem 1 %32
    • The RAM should be easily removed once released from the plastic clips.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
1Comentário do guia
Windows 98 Product Key?
Dudefoxlive - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 33
Ao todo: 439
