Introdução
The Motherboard is a important component of the laptop. It is responsible for connecting components and communicating between various electronic parts of the device, such as the memory and and the central processing unit. This guide shows how to replace a faulty motherboard with a new motherboard. For more information about the effects of a faulty motherboard please check out our troubleshooting page. Please be aware that the motherboard is connected to many parts of the device and requires a lot of time to disassemble and re-assemble.
O que você precisa
Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
Remove three 6.5 mm Phillips screws located underneath the keyboard using a Phillips #0 screwdriver.
Uma outra pessoa concluiu este guia.
