Ir para o conteúdo principal
HP Pavilion 17-e117dx Optical Drive Replacement
O que você precisa
  1. HP Pavilion 17-e117dx Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop upside down, so that the bottom is facing up.
    Pergunte ao FixBot
    Comentar
  2. HP Pavilion 17-e117dx Optical Drive Replacement: passo 2, imagem 1 %32 HP Pavilion 17-e117dx Optical Drive Replacement: passo 2, imagem 2 %32
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
    Pergunte ao FixBot
    Comentar
  3. HP Pavilion 17-e117dx Optical Drive Replacement, Service Panel: passo 3, imagem 1 %32 HP Pavilion 17-e117dx Optical Drive Replacement, Service Panel: passo 3, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
    Pergunte ao FixBot
    Comentar
  4. HP Pavilion 17-e117dx Optical Drive Replacement: passo 4, imagem 1 %32
    • Slide the service panel towards you to loosen it from the laptop.
    Pergunte ao FixBot
    Comentar
  5. HP Pavilion 17-e117dx Optical Drive Replacement: passo 5, imagem 1 %32
    • Remove the service panel.
    Pergunte ao FixBot
    Comentar
  6. HP Pavilion 17-e117dx Optical Drive Replacement, Optical Drive: passo 6, imagem 1 %32 HP Pavilion 17-e117dx Optical Drive Replacement, Optical Drive: passo 6, imagem 2 %32
    • Remove the single Phillips PM 2.5 x 5.75 screw that secures the optical drive to the computer.
    • Use the Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. HP Pavilion 17-e117dx Optical Drive Replacement: passo 7, imagem 1 %32 HP Pavilion 17-e117dx Optical Drive Replacement: passo 7, imagem 2 %32 HP Pavilion 17-e117dx Optical Drive Replacement: passo 7, imagem 3 %32
    • Slide the optical drive out of the computer.
    Pergunte ao FixBot
    Comentar
Conclusão
Marcel Amazan
Membro desde: 03/24/19
594 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 583
