Ir para o conteúdo principal
HP Pavilion 17 TS RAM Replacement
O que você precisa
  1. HP Pavilion 17 TS RAM Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 17 TS RAM Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion 17 TS RAM Replacement, Battery: passo 1, imagem 3 %32
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
    Pergunte ao FixBot
    Comentar
  2. HP Pavilion 17 TS RAM Replacement, Rear Cover: passo 2, imagem 1 %32 HP Pavilion 17 TS RAM Replacement, Rear Cover: passo 2, imagem 2 %32 HP Pavilion 17 TS RAM Replacement, Rear Cover: passo 2, imagem 3 %32
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
    Pergunte ao FixBot
    Comentar
  3. HP Pavilion 17 TS RAM Replacement, RAM: passo 3, imagem 1 %32 HP Pavilion 17 TS RAM Replacement, RAM: passo 3, imagem 2 %32 HP Pavilion 17 TS RAM Replacement, RAM: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • On each side of each RAM card, there will be a thin strip of metal that is holding the chip down. Using tweezers or another thin tool, gently push these pins apart.
    • The first RAM card should pop up on its own. Gently remove this card, and look for the two strips of metal holding the bottom card down.
    • Push the pins apart just like for card one. Just like the first card, this one will pop up and you can remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
Eric Sowersby
Membro desde: 03/25/16
413 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 922
