Ir para o conteúdo principal
HP Pavilion 15-e043cl RAM Replacement
O que você precisa
  1. HP Pavilion 15-e043cl RAM Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 15-e043cl RAM Replacement, Battery: passo 1, imagem 2 %32
    • Flip the device over.
    • Slide the battery switch on the right half of the laptop.
    • Make sure the device is powered off, and that it is not connected to any power sources.
    Pergunte ao FixBot
    Comentar
  2. HP Pavilion 15-e043cl RAM Replacement: passo 2, imagem 1 %32 HP Pavilion 15-e043cl RAM Replacement: passo 2, imagem 2 %32
    • Lift the battery up and out of the device by the inward-facing edge.
    Pergunte ao FixBot
    Comentar
  3. HP Pavilion 15-e043cl RAM Replacement, Maintenance Panel: passo 3, imagem 1 %32 HP Pavilion 15-e043cl RAM Replacement, Maintenance Panel: passo 3, imagem 2 %32 HP Pavilion 15-e043cl RAM Replacement, Maintenance Panel: passo 3, imagem 3 %32
    • Unscrew the single Phillips #0 captive screw that was previously hidden by the battery.
    • The screw can not, and should not, be fully removed.
    • Slide the maintenance panel away from the battery compartment to release it.
    Pergunte ao FixBot
    Comentar
  4. HP Pavilion 15-e043cl RAM Replacement, RAM: passo 4, imagem 1 %32 HP Pavilion 15-e043cl RAM Replacement, RAM: passo 4, imagem 2 %32
    • Push the two silver arms away from the RAM card.
    • Pull the RAM card out of its slot.
    Pergunte ao FixBot
    Comentar
Conclusão
Cace Letendre
Membro desde: 10/25/22
528 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 4-5, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-5, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G5
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 8
Últimos 30 dias: 39
Ao todo: 379
