Ir para o conteúdo principal
HP Pavilion 15-cd040wm Battery Replacement
O que você precisa
  1. HP Pavilion 15-cd040wm Battery Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: passo 1, imagem 1 %32 HP Pavilion 15-cd040wm Battery Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: passo 1, imagem 2 %32
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Battery Replacement: passo 2, imagem 1 %32 HP Pavilion 15-cd040wm Battery Replacement: passo 2, imagem 2 %32
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Battery Replacement: passo 3, imagem 1 %32 HP Pavilion 15-cd040wm Battery Replacement: passo 3, imagem 2 %32 HP Pavilion 15-cd040wm Battery Replacement: passo 3, imagem 3 %32
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm Battery Replacement, Battery: passo 4, imagem 1 %32 HP Pavilion 15-cd040wm Battery Replacement, Battery: passo 4, imagem 2 %32
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm Battery Replacement: passo 5, imagem 1 %32 HP Pavilion 15-cd040wm Battery Replacement: passo 5, imagem 2 %32
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Joe Krawczyk
Membro desde: 11/01/19
397 Reputação
Autoria de 2 guias
Equipe
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 36
Ao todo: 2,201
