Ir para o conteúdo principal
HP Pavilion 15-ba003ds RAM Replacement
O que você precisa
  1. HP Pavilion 15-ba003ds RAM Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 15-ba003ds RAM Replacement, Battery: passo 1, imagem 2 %32
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
    Pergunte ao FixBot
    Comentar
  2. HP Pavilion 15-ba003ds RAM Replacement, Disc Drive: passo 2, imagem 1 %32
    • Use a spudger to remove the two rubber feet next to the battery.
    • This will reveal two hidden screws.
    • Save the feet for reassembly.
    Pergunte ao FixBot
    Comentar
  3. HP Pavilion 15-ba003ds RAM Replacement: passo 3, imagem 1 %32 HP Pavilion 15-ba003ds RAM Replacement: passo 3, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove twelve 8 mm screws from the bottom of your laptop including the two screws found underneath the rubber feet.
    Pergunte ao FixBot
    Comentar
  4. HP Pavilion 15-ba003ds RAM Replacement: passo 4, imagem 1 %32 HP Pavilion 15-ba003ds RAM Replacement: passo 4, imagem 2 %32
    • Pull the disc drive from your laptop to remove it.
    Pergunte ao FixBot
    Comentar
  5. HP Pavilion 15-ba003ds RAM Replacement, Backplate: passo 5, imagem 1 %32 HP Pavilion 15-ba003ds RAM Replacement, Backplate: passo 5, imagem 2 %32 HP Pavilion 15-ba003ds RAM Replacement, Backplate: passo 5, imagem 3 %32
    • Use a Jimmy to pry off the black backplate.
    Pergunte ao FixBot
    Comentar
  6. HP Pavilion 15-ba003ds RAM Replacement, RAM Module: passo 6, imagem 1 %32 HP Pavilion 15-ba003ds RAM Replacement, RAM Module: passo 6, imagem 2 %32
    • To release the RAM, hold and pull the strips outwards on either side of the RAM.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 534
