Ir para o conteúdo principal
HP Pavilion 14-v062us Keyboard Replacement
O que você precisa
  1. HP Pavilion 14-v062us Keyboard Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 14-v062us Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Power laptop off and make sure it is not plugged into charger
    • Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
  2. HP Pavilion 14-v062us Keyboard Replacement: passo 2, imagem 1 %32 HP Pavilion 14-v062us Keyboard Replacement: passo 2, imagem 2 %32
    • Lift the battery upwards and out from the laptop
  3. HP Pavilion 14-v062us Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 HP Pavilion 14-v062us Keyboard Replacement, Keyboard: passo 3, imagem 2 %32 HP Pavilion 14-v062us Keyboard Replacement, Keyboard: passo 3, imagem 3 %32
    • Remove rectangular rubber tops with a spudger
    • Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
    • Remove plastic edge covering with the blue plastic opening tool.
    • Remove two 4.63 mm PH#1 screws located under plastic edge covering.
  4. HP Pavilion 14-v062us Keyboard Replacement: passo 4, imagem 1 %32 HP Pavilion 14-v062us Keyboard Replacement: passo 4, imagem 2 %32
    • Use Phillips screwdriver #1
    • Remove all nine 7.09 mm PH#1 screw black screws including small rectangular cover.
    • Remove the three 7.14 mm PH#1 screws.
    • Remove the one 7.09 mm PH#1 screw that will be underneath the small rectangular cover
  5. HP Pavilion 14-v062us Keyboard Replacement: passo 5, imagem 1 %32 HP Pavilion 14-v062us Keyboard Replacement: passo 5, imagem 2 %32
    • Remove disc tray
    • Locate screw within computer that is inside of where the disc tray was
    • Using a Phillips #1 screwdriver, unscrew the screw
    • Set laptop down and open laptop so the keyboard is facing you
  6. HP Pavilion 14-v062us Keyboard Replacement: passo 6, imagem 1 %32 HP Pavilion 14-v062us Keyboard Replacement: passo 6, imagem 2 %32 HP Pavilion 14-v062us Keyboard Replacement: passo 6, imagem 3 %32
    • Using a spudger or plastic opening tool, pry along siding of keyboard, where it connects to the rest of the laptop
    • Pry until you are able to lift entire face and keyboard
    • Only cables should be connecting it underneath
  7. HP Pavilion 14-v062us Keyboard Replacement: passo 7, imagem 1 %32 HP Pavilion 14-v062us Keyboard Replacement: passo 7, imagem 2 %32 HP Pavilion 14-v062us Keyboard Replacement: passo 7, imagem 3 %32
    • Disconnect/ unplug cables using plastic opening tool.
    • Separate the keyboard panel from the laptop with your hands.
    • Turn around the laptop and lay it flat.
  8. HP Pavilion 14-v062us Keyboard Replacement: passo 8, imagem 1 %32 HP Pavilion 14-v062us Keyboard Replacement: passo 8, imagem 2 %32
    • Use a spudger to pry around the first layer of the silver panel until you are able to remove it
    • Only use a metal spudger as a last resort
  9. HP Pavilion 14-v062us Keyboard Replacement: passo 9, imagem 1 %32 HP Pavilion 14-v062us Keyboard Replacement: passo 9, imagem 2 %32 HP Pavilion 14-v062us Keyboard Replacement: passo 9, imagem 3 %32
    • Using a spudger tool, start prying around the second layer of the silver panel until you are able to remove it
Conclusão
2 comentários
Thank you so much, this guide is very helpful.
Rodolfo Trujillo - Responder
Thank you for the guide. It was very helpful!
dmitryp80 - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 14
Ao todo: 1,998
