Ir para o conteúdo principal
HP Pavilion 14-bk061st Heat Sink Replacement
O que você precisa
  1. HP Pavilion 14-bk061st Heat Sink Replacement, Back Panel: passo 1, imagem 1 %32 HP Pavilion 14-bk061st Heat Sink Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Heat Sink Replacement: passo 2, imagem 1 %32
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Heat Sink Replacement: passo 3, imagem 1 %32
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Heat Sink Replacement, Heat Sink: passo 4, imagem 1 %32 HP Pavilion 14-bk061st Heat Sink Replacement, Heat Sink: passo 4, imagem 2 %32
    • Remove the four 2.9mm JIS #1 screws from each of the four corners of the fan.
  5. HP Pavilion 14-bk061st Heat Sink Replacement: passo 5, imagem 1 %32
    • Carefully grab the heat sink from any side and lift straight up while trying to avoid touching other components.
    • Avoid bending the heat-pipe at all costs to keep it functional.
Conclusão
Uma outra pessoa concluiu este guia.
Stefano Lo Re
Membro desde: 01/22/20
382 Reputação
Autoria de 3 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 16
Ao todo: 354
