Ir para o conteúdo principal
HP Pavilion 13-P110NR Keyboard Replacement
O que você precisa
  1. HP Pavilion 13-P110NR Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove the two rubber feet closest to the black hinge.
  2. HP Pavilion 13-P110NR Keyboard Replacement: passo 2, imagem 1 %32 HP Pavilion 13-P110NR Keyboard Replacement: passo 2, imagem 2 %32
    • Remove two 6.0 mm Philips #00 screws from the back casing.
    • Remove four 5.0 mm Philips #00 screws from the back casing.
  3. HP Pavilion 13-P110NR Keyboard Replacement: passo 3, imagem 1 %32
    • On the silver metal brace, remove the four 6.0 mm Phillips #00 screws.
  4. HP Pavilion 13-P110NR Keyboard Replacement: passo 4, imagem 1 %32
    • Lift the metal brace and remove it from the device.
  5. HP Pavilion 13-P110NR Keyboard Replacement: passo 5, imagem 1 %32 HP Pavilion 13-P110NR Keyboard Replacement: passo 5, imagem 2 %32
    • Unflip the lock on the wire tape and lift that end of the tape away.
    • Do the same for the small white piece of tape on the circuit board.
  6. HP Pavilion 13-P110NR Keyboard Replacement: passo 6, imagem 1 %32 HP Pavilion 13-P110NR Keyboard Replacement: passo 6, imagem 2 %32
    • Remove the eight 6.0 mm Philips #00 screws from the two silver holds.
  7. HP Pavilion 13-P110NR Keyboard Replacement: passo 7, imagem 1 %32
    • Remove five 5.0 mm Philips #00 screws from the green circuit boards.
  8. HP Pavilion 13-P110NR Keyboard Replacement: passo 8, imagem 1 %32 HP Pavilion 13-P110NR Keyboard Replacement: passo 8, imagem 2 %32 HP Pavilion 13-P110NR Keyboard Replacement: passo 8, imagem 3 %32
    • Lift the white pieces up.
    • Once lifted, peel the black film away to reveal a metal plate with many black glue pieces.
  9. HP Pavilion 13-P110NR Keyboard Replacement: passo 9, imagem 1 %32
    • Using the spudger, pry each glue piece off of the metal brace. All glue pieces must be removed.
    • Use caution, the pieces may fly when they are forced out.
  10. HP Pavilion 13-P110NR Keyboard Replacement: passo 10, imagem 1 %32
    • Remove the metal plate to reveal the keyboard.
  11. HP Pavilion 13-P110NR Keyboard Replacement: passo 11, imagem 1 %32 HP Pavilion 13-P110NR Keyboard Replacement: passo 11, imagem 2 %32
    • Remove the keyboard from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 316
