Ir para o conteúdo principal
HP Pavilion 13-P110NR Battery Replacement
O que você precisa
  1. HP Pavilion 13-P110NR Battery Replacement, Battery: passo 1, imagem 1 %32
    • Gently use the black nylon spudger to pry the back casing from the screen until it snaps apart.
  2. HP Pavilion 13-P110NR Battery Replacement: passo 2, imagem 1 %32 HP Pavilion 13-P110NR Battery Replacement: passo 2, imagem 2 %32
    • Flip the gray latch back and remove the blue and white band of wires from the green motherboard.
  3. HP Pavilion 13-P110NR Battery Replacement: passo 3, imagem 1 %32 HP Pavilion 13-P110NR Battery Replacement: passo 3, imagem 2 %32 HP Pavilion 13-P110NR Battery Replacement: passo 3, imagem 3 %32
    • Pull the black and white wire out of the green circuit board.
    • Pull the red and black wire out on the other side of the device.
  4. HP Pavilion 13-P110NR Battery Replacement: passo 4, imagem 1 %32 HP Pavilion 13-P110NR Battery Replacement: passo 4, imagem 2 %32
    • Unscrew the three screws from the circuit board using a Phillips #00 screwdriver.
    • Unscrew two 4.0 mm Philips #00 screws from the left side of the battery.
    • Unscrew two 3.0 mm Philips #00 screws from the right side of the battery.
  5. HP Pavilion 13-P110NR Battery Replacement: passo 5, imagem 1 %32 HP Pavilion 13-P110NR Battery Replacement: passo 5, imagem 2 %32
    • Unplug the bound (red, white and black) wires connecting the battery and the motherboard.
  6. HP Pavilion 13-P110NR Battery Replacement: passo 6, imagem 1 %32 HP Pavilion 13-P110NR Battery Replacement: passo 6, imagem 2 %32
    • Carefully remove the battery without pulling the copper information transmitter out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 542
