Ir para o conteúdo principal
HP Officejet Pro 8625 Display Replacement
O que você precisa
  1. HP Officejet Pro 8625 Display  Replacement, Display Motherboard: passo 1, imagem 1 %32 HP Officejet Pro 8625 Display  Replacement, Display Motherboard: passo 1, imagem 2 %32
    • Disconnect the display by holding it in place while pulling down on the plastic hinge.
    • Slowly apply more and more force as it does take a lot to separate, do not worry about the hinge or display breaking.
    Pergunte ao FixBot
    Comentar
  2. HP Officejet Pro 8625 Display  Replacement: passo 2, imagem 1 %32 HP Officejet Pro 8625 Display  Replacement: passo 2, imagem 2 %32 HP Officejet Pro 8625 Display  Replacement: passo 2, imagem 3 %32
    • Lift the display as high as it will allow to expose the back of the display.
    • Pinch the sides of the cover and pull away from the printer to reveal the connector.
    • Remove the connector by pulling both away from the display and towards the printer.
    Pergunte ao FixBot
    Comentar
  3. HP Officejet Pro 8625 Display  Replacement: passo 3, imagem 1 %32 HP Officejet Pro 8625 Display  Replacement: passo 3, imagem 2 %32 HP Officejet Pro 8625 Display  Replacement: passo 3, imagem 3 %32
    • Remove the four 6.2 mm T9 screws from the back of the display.
    • Pull the display assembly up and away from the printer.
    Pergunte ao FixBot
    Comentar
  4. HP Officejet Pro 8625 Display  Replacement: passo 4, imagem 1 %32 HP Officejet Pro 8625 Display  Replacement: passo 4, imagem 2 %32
    • Remove the back cover from the display assembly by pressing down on the point of connection.
    • If you use a plastic spudger for this step, be careful not to brake the plastic as you do not need to use much force to remove the back cover.
    Pergunte ao FixBot
    Comentar
  5. HP Officejet Pro 8625 Display  Replacement: passo 5, imagem 1 %32 HP Officejet Pro 8625 Display  Replacement: passo 5, imagem 2 %32
    • Remove the four 4.8 mm T6 screws from the back of the display motherboard.
    Pergunte ao FixBot
    Comentar
  6. HP Officejet Pro 8625 Display  Replacement: passo 6, imagem 1 %32 HP Officejet Pro 8625 Display  Replacement: passo 6, imagem 2 %32
    • Remove the connection on the front of the display motherboard.
    • Remove the display motherboard.
    Pergunte ao FixBot
    Comentar
  7. HP Officejet Pro 8625 Display  Replacement, Display: passo 7, imagem 1 %32 HP Officejet Pro 8625 Display  Replacement, Display: passo 7, imagem 2 %32
    • Remove the four 4.8 mm screws from the back of the display using a T6 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. HP Officejet Pro 8625 Display  Replacement: passo 8, imagem 1 %32 HP Officejet Pro 8625 Display  Replacement: passo 8, imagem 2 %32 HP Officejet Pro 8625 Display  Replacement: passo 8, imagem 3 %32
    • Lift the display out of the case.
    Pergunte ao FixBot
    Comentar
Conclusão
Cole Andrews
Membro desde: 10/08/18
273 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S13-G3, White Fall 2018 Membro de Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 871
