Ir para o conteúdo principal
HP OfficeJet 4650 Power Button Replacement
O que você precisa
  1. HP OfficeJet 4650 Power Button Replacement, Power Button: passo 1, imagem 1 %32 HP OfficeJet 4650 Power Button Replacement, Power Button: passo 1, imagem 2 %32 HP OfficeJet 4650 Power Button Replacement, Power Button: passo 1, imagem 3 %32
    • Open the cartridge access door by putting one hand on the grooves of each side and pulling up.
    Pergunte ao FixBot
    Comentar
  2. HP OfficeJet 4650 Power Button Replacement: passo 2, imagem 1 %32 HP OfficeJet 4650 Power Button Replacement: passo 2, imagem 2 %32
    • Using the 2.0 mm hex screwdriver, remove the 14 mm hex screw that binds the front cover to the printer body by turning the screw counterclockwise.
    Pergunte ao FixBot
    Comentar
  3. HP OfficeJet 4650 Power Button Replacement: passo 3, imagem 1 %32 HP OfficeJet 4650 Power Button Replacement: passo 3, imagem 2 %32 HP OfficeJet 4650 Power Button Replacement: passo 3, imagem 3 %32
    • Release the front panel from its internal hooks by applying a little force and sliding the front panel to the right.
    • Push the panel upward to remove it from the printer.
    • There is a connector attached to the back of the panel. Flip the front cover towards you gently and proceed to the next step.
    Pergunte ao FixBot
    Comentar
  4. HP OfficeJet 4650 Power Button Replacement: passo 4, imagem 1 %32 HP OfficeJet 4650 Power Button Replacement: passo 4, imagem 2 %32 HP OfficeJet 4650 Power Button Replacement: passo 4, imagem 3 %32
    • Remove the connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from the circuit board.
    Pergunte ao FixBot
    Comentar
  5. HP OfficeJet 4650 Power Button Replacement: passo 5, imagem 1 %32 HP OfficeJet 4650 Power Button Replacement: passo 5, imagem 2 %32 HP OfficeJet 4650 Power Button Replacement: passo 5, imagem 3 %32
    • Using the Torx T6 hex screwdriver, remove the 7.0mm screw that binds the front cover to the printer body by turning the screw counterclockwise.
    Pergunte ao FixBot
    Comentar
  6. HP OfficeJet 4650 Power Button Replacement: passo 6, imagem 1 %32 HP OfficeJet 4650 Power Button Replacement: passo 6, imagem 2 %32 HP OfficeJet 4650 Power Button Replacement: passo 6, imagem 3 %32
    • Remove the connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from button circuit board.
    Pergunte ao FixBot
    Comentar
  7. HP OfficeJet 4650 Power Button Replacement: passo 7, imagem 1 %32 HP OfficeJet 4650 Power Button Replacement: passo 7, imagem 2 %32 HP OfficeJet 4650 Power Button Replacement: passo 7, imagem 3 %32
    • Pop the button off from the black cover by using your finger tip to bring it up.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S19-G6, Livingston Winter 2018 Membro de Cal Poly, Team S19-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G6
3 Membros
Autoria de 10 guias
6Comentários do guia
Does this fix the printer not turning on?
cindim - Responder Compartilhar
Where can I purchase the replacement Power Button? What is the part number?
Mort Rosenberg - Responder Compartilhar
Is it possible to bypass the malfunctioning power button, so the printer is on whenever it is plugged in? If so, how?
Ron Sela - Responder Compartilhar
Jack Farr
Jack Farr - Responder Compartilhar
Bonjour,
Ou peut on acheter l'écran tactile HP Officejet 4650 ???
Georges N'GUELA - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 56
Ao todo: 4,289
