Ir para o conteúdo principal
HP Notebook 15-ba018ds RAM Replacement
O que você precisa
    1. HP Notebook 15-ba018ds RAM Replacement, Battery: passo 1, imagem 1 %32
      • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
      • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
      Pergunte ao FixBot
      Comentar
    2. HP Notebook 15-ba018ds RAM Replacement: passo 2, imagem 1 %32 HP Notebook 15-ba018ds RAM Replacement: passo 2, imagem 2 %32 HP Notebook 15-ba018ds RAM Replacement: passo 2, imagem 3 %32
      • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
      • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
      Pergunte ao FixBot
      Comentar
    1. HP Notebook 15-ba018ds RAM Replacement, RAM: passo 3, imagem 1 %32 HP Notebook 15-ba018ds RAM Replacement, RAM: passo 3, imagem 2 %32
      • Unscrew the 8 screws on the back cover.
      • There are also two screws in the battery area that you unscrew.
      Pergunte ao FixBot
      Comentar
    2. HP Notebook 15-ba018ds RAM Replacement: passo 4, imagem 1 %32
      • Use an opening tool and wedge it under the edge and go around the whole laptop to help remove the back cover.
      • On the side of the laptop, you can see where it can be separated into two parts.
      Pergunte ao FixBot
      Comentar
    3. HP Notebook 15-ba018ds RAM Replacement: passo 5, imagem 1 %32 HP Notebook 15-ba018ds RAM Replacement: passo 5, imagem 2 %32 HP Notebook 15-ba018ds RAM Replacement: passo 5, imagem 3 %32
      • This laptop has one RAM.
      • Gently pull out the RAM from the socket.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 42
Ao todo: 1,641
