Ir para o conteúdo principal
HP Mini 311 Keyboard Replacement
O que você precisa
    1. HP Mini 311 Keyboard Replacement, Battery: passo 1, imagem 1 %32 HP Mini 311 Keyboard Replacement, Battery: passo 1, imagem 2 %32 HP Mini 311 Keyboard Replacement, Battery: passo 1, imagem 3 %32
      • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
      Pergunte ao FixBot
      Comentar
    2. HP Mini 311 Keyboard Replacement: passo 2, imagem 1 %32 HP Mini 311 Keyboard Replacement: passo 2, imagem 2 %32
      • Slide the battery away from the device to remove.
      Pergunte ao FixBot
      Comentar
    1. HP Mini 311 Keyboard Replacement, Memory Shield: passo 3, imagem 1 %32
      • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
      • The screws will remain in the shied.
      Pergunte ao FixBot
      Comentar
    2. HP Mini 311 Keyboard Replacement: passo 4, imagem 1 %32 HP Mini 311 Keyboard Replacement: passo 4, imagem 2 %32
      • Lift the memory shield up and remove from the laptop.
      Pergunte ao FixBot
      Comentar
    1. HP Mini 311 Keyboard Replacement, Hard Drive: passo 5, imagem 1 %32 HP Mini 311 Keyboard Replacement, Hard Drive: passo 5, imagem 2 %32 HP Mini 311 Keyboard Replacement, Hard Drive: passo 5, imagem 3 %32
      • Grab the left black, plastic tab and carefully pull upward.
      • Be sure to pull carefully. Pulling too forcefully may damage the tab.
      Pergunte ao FixBot
      Comentar
    2. HP Mini 311 Keyboard Replacement: passo 6, imagem 1 %32 HP Mini 311 Keyboard Replacement: passo 6, imagem 2 %32 HP Mini 311 Keyboard Replacement: passo 6, imagem 3 %32
      • Grab a hold of the wire connecting the hard drive and the device.
      • Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard.
      Pergunte ao FixBot
      Comentar
    1. HP Mini 311 Keyboard Replacement, Keyboard: passo 7, imagem 1 %32
      • Unscrew the four Phillip 00 5.6 mm screws located around the wireless card and RAM.
      Pergunte ao FixBot
      Comentar
    2. HP Mini 311 Keyboard Replacement: passo 8, imagem 1 %32
      • Open the laptop so that the screen and front of the keyboard are both facing the ground.
      • Push on the opening on the back side of the device until the keyboard partially pops out.
      • This opening is located where the original hard drive was set.
      Pergunte ao FixBot
      Comentar
    3. HP Mini 311 Keyboard Replacement: passo 9, imagem 1 %32 HP Mini 311 Keyboard Replacement: passo 9, imagem 2 %32 HP Mini 311 Keyboard Replacement: passo 9, imagem 3 %32
      • Flip the device around and orient it so that the screen and keyboard are facing you.
      • Starting at the right side, work your way towards the left end and remove the keyboard by unhinging the latches attaching it to the base of the device.
      • The right side of the keyboard should be unattached.
      • Be gentle and patient. You don't want to pull the entire keyboard at once, but rather pull by sections.
      Pergunte ao FixBot
      Comentar
    4. HP Mini 311 Keyboard Replacement: passo 10, imagem 1 %32 HP Mini 311 Keyboard Replacement: passo 10, imagem 2 %32 HP Mini 311 Keyboard Replacement: passo 10, imagem 3 %32
      • Carefully pull the ribbon cable connecting the keyboard and the laptop to remove from the device.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 20-4, Maness Winter 2013 Membro de Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Membros
Autoria de 49 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 37
Ao todo: 3,011
