Ir para o conteúdo principal
HP Mini 311 Hard Drive Replacement
O que você precisa
    1. HP Mini 311 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP Mini 311 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 HP Mini 311 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
      • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
      Pergunte ao FixBot
      Comentar
    2. HP Mini 311 Hard Drive Replacement: passo 2, imagem 1 %32 HP Mini 311 Hard Drive Replacement: passo 2, imagem 2 %32
      • Slide the battery away from the device to remove.
      Pergunte ao FixBot
      Comentar
    1. HP Mini 311 Hard Drive Replacement, Memory Shield: passo 3, imagem 1 %32
      • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
      • The screws will remain in the shied.
      Pergunte ao FixBot
      Comentar
    2. HP Mini 311 Hard Drive Replacement: passo 4, imagem 1 %32 HP Mini 311 Hard Drive Replacement: passo 4, imagem 2 %32
      • Lift the memory shield up and remove from the laptop.
      Pergunte ao FixBot
      Comentar
    1. HP Mini 311 Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32 HP Mini 311 Hard Drive Replacement, Hard Drive: passo 5, imagem 2 %32 HP Mini 311 Hard Drive Replacement, Hard Drive: passo 5, imagem 3 %32
      • Grab the left black, plastic tab and carefully pull upward.
      • Be sure to pull carefully. Pulling too forcefully may damage the tab.
      Pergunte ao FixBot
      Comentar
    2. HP Mini 311 Hard Drive Replacement: passo 6, imagem 1 %32 HP Mini 311 Hard Drive Replacement: passo 6, imagem 2 %32 HP Mini 311 Hard Drive Replacement: passo 6, imagem 3 %32
      • Grab a hold of the wire connecting the hard drive and the device.
      • Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 20-4, Maness Winter 2013 Membro de Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Membros
Autoria de 31 guias
1Comentário do guia
What size hard drive does this unit take?
Travis Duncan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 33
Ao todo: 4,944
