Ir para o conteúdo principal
HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement
O que você precisa
  1. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Battery and Service Access Cover: passo 1, imagem 1 %32
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
    Pergunte ao FixBot
    Comentar
  2. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: passo 2, imagem 1 %32 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: passo 2, imagem 2 %32 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: passo 2, imagem 3 %32
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
    Pergunte ao FixBot
    Comentar
  3. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: passo 3, imagem 1 %32 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: passo 3, imagem 2 %32 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: passo 3, imagem 3 %32
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
    Pergunte ao FixBot
    Comentar
  4. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: passo 4, imagem 1 %32
    • Orient the computer as shown in the picture.
    Pergunte ao FixBot
    Comentar
  5. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Wi-Fi Card (WLAN Module): passo 5, imagem 1 %32 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement, Wi-Fi Card (WLAN Module): passo 5, imagem 2 %32
    • Locate the Wi-Fi Card (WLAN Module), near the computer's bottom left corner.
    Pergunte ao FixBot
    Comentar
  6. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: passo 6, imagem 1 %32 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: passo 6, imagem 2 %32 HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: passo 6, imagem 3 %32
    • Disconnect the two cables from the Wi-Fi card by gently lifting them away from the card.
    • There should be two black cables, one labeled with a white sticker, connected to the module.
    Pergunte ao FixBot
    Comentar
  7. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: passo 7, imagem 1 %32
    • Remove the two 2.0 x 3.0 screws securing the Wi-Fi card using a Phillips #00 screwdriver
    • The card should tilt up away from the laptop at an angle after removing the screws.
    Pergunte ao FixBot
    Comentar
  8. HP Mini 210-2070NR Wi-Fi Card (WLAN Module) Replacement: passo 8, imagem 1 %32
    • Remove the Wi-Fi card by gently pulling it out of its slot at an angle.
    • Potential for device damage: Be sure to pull gently and at an angle away from you. If the card is pulled straight up, there is a chance it could break or bend.
    Pergunte ao FixBot
    Comentar
Conclusão
Taylor
Membro desde: 10/05/12
116 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 3-23, Amido Fall 2012 Membro de Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 31
Ao todo: 1,573
