Ir para o conteúdo principal
HP Mini 210-2070NR RAM Replacement
O que você precisa
  1. HP Mini 210-2070NR RAM Replacement, Battery and Service Access Cover: passo 1, imagem 1 %32
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
    Pergunte ao FixBot
    Comentar
  2. HP Mini 210-2070NR RAM Replacement: passo 2, imagem 1 %32 HP Mini 210-2070NR RAM Replacement: passo 2, imagem 2 %32 HP Mini 210-2070NR RAM Replacement: passo 2, imagem 3 %32
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
    Pergunte ao FixBot
    Comentar
  3. HP Mini 210-2070NR RAM Replacement: passo 3, imagem 1 %32 HP Mini 210-2070NR RAM Replacement: passo 3, imagem 2 %32 HP Mini 210-2070NR RAM Replacement: passo 3, imagem 3 %32
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
    Pergunte ao FixBot
    Comentar
  4. HP Mini 210-2070NR RAM Replacement: passo 4, imagem 1 %32
    • Orient the computer as shown in the picture.
    Pergunte ao FixBot
    Comentar
  5. HP Mini 210-2070NR RAM Replacement, RAM: passo 5, imagem 1 %32
    • Using your fingers, pull the two white clips (tabs) on both sides of the RAM away from each other. Keep pulling the clips until the RAM pops up
    • Hold the RAM on the edges only. Touching the components on the RAM might damage it.
    Pergunte ao FixBot
    Comentar
  6. HP Mini 210-2070NR RAM Replacement: passo 6, imagem 1 %32
    • Grab the edges of the module and gently lift it from the slot.
    • RAM Cards are designed with a notch on the surface to prevent incorrect insertion into the memory module slot.
    Pergunte ao FixBot
    Comentar
Conclusão
Sean Kuster
Membro desde: 10/05/12
91 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 3-23, Amido Fall 2012 Membro de Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Ao todo: 2,466
