Ir para o conteúdo principal
HP Mini 210-1199DX CMOS Battery Replacement
O que você precisa
  1. HP Mini 210-1199DX CMOS Battery Replacement, Battery: passo 1, imagem 1 %32 HP Mini 210-1199DX CMOS Battery Replacement, Battery: passo 1, imagem 2 %32
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
    Pergunte ao FixBot
    Comentar
  2. HP Mini 210-1199DX CMOS Battery Replacement: passo 2, imagem 1 %32
    • Remove the battery from the device.
    Pergunte ao FixBot
    Comentar
  3. HP Mini 210-1199DX CMOS Battery Replacement, Bottom Cover: passo 3, imagem 1 %32
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
    Pergunte ao FixBot
    Comentar
  4. HP Mini 210-1199DX CMOS Battery Replacement: passo 4, imagem 1 %32 HP Mini 210-1199DX CMOS Battery Replacement: passo 4, imagem 2 %32 HP Mini 210-1199DX CMOS Battery Replacement: passo 4, imagem 3 %32
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
    Pergunte ao FixBot
    Comentar
  5. HP Mini 210-1199DX CMOS Battery Replacement: passo 5, imagem 1 %32
    • Pull the case off of the device
    Pergunte ao FixBot
    Comentar
  6. HP Mini 210-1199DX CMOS Battery Replacement, CMOS Battery: passo 6, imagem 1 %32 HP Mini 210-1199DX CMOS Battery Replacement, CMOS Battery: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Simply pull the small black ribbon off of the battery with either your finger or a pair of tweezers.
    Pergunte ao FixBot
    Comentar
  7. HP Mini 210-1199DX CMOS Battery Replacement: passo 7, imagem 1 %32 HP Mini 210-1199DX CMOS Battery Replacement: passo 7, imagem 2 %32
    • Using the spudger, carefully pop the battery out of the right side as seen in the picture.
    • To reinstall, carefully place slide the battery back into place with the positive side facing upwards.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 1,075
